bobbrown wrote:Check it is bled correctly, does it work on the foot brake?
Bob
bobbrown wrote:Try giving Hi Spec a ring on 01322 286850 because if the foot brake works I can see no reason the handbrake should not work
paulwatkins wrote:bobbrown wrote:Try giving Hi Spec a ring on 01322 286850 because if the foot brake works I can see no reason the handbrake should not work
Just done that.......and off the caliper comes again to go back to Lo Spec.
GeoffSmith wrote:paulwatkins wrote:bobbrown wrote:Try giving Hi Spec a ring on 01322 286850 because if the foot brake works I can see no reason the handbrake should not work
WHY?
mnemonix wrote:What improvement I could feel may have come simply from a change in adjustment putting the next click at a slightly more accessible point in the handbrake lever travel or possibly as a result of the springs inside the caliper no longer being coil bound. Whichever, it isn't enough to imrove the ease of application enough for a regular MOT pass.
