by GeoffSmith » Mon 13.08.2007, 20:27
It looks like a control module to me, together with a couple of spare connectors.
- Kitty Fiddler
by petestubbs » Mon 13.08.2007, 22:12
Well I'm hoping Geoff is right!!
Really really hoping
petestubbs
by Sy V » Tue 14.08.2007, 10:19
Geoff's right.
The centre part houses the switching unit that is prone to stick, which can sometimes be freed by tapping on the outer casing.
However, dont use the knuckle of your middle finger 'cos that small circular dimple in the middle is designed to remove skin...and I speak from first-hand experience!
- LEC Godfather
by petestubbs » Thu 06.09.2007, 15:28
Well, Geoff was right, it was the correct unit and with a couple of spare connectors.
Sadly when fitted it works worst than mine
My one made one headlight work this one does nothing.
Looks like I've been conned
Anybody got a spare control module for sale
petestubbs
by nitroman » Wed 02.11.2011, 23:50
Candles wrote:Following alternator overvolt trouble, I immediately suspected my Headlamp Control Module. Actually the bulbs had blown, which amazingly stops the pods coming up!
Candles.
I found that this is the case in the Lotus manual. I replaced the controller module to no effect, so am hoping this is the cause of my problem as well. I'll replace the bulbs tomorrow and see what happens.
I had driven the car for 11 straight hours at night with the lights on with no problem, but the next time I started the car 2 days later my trouble began.
Did replacing the bulbs fix yours?
nitroman
by epipete » Thu 03.11.2011, 00:45
If you need a module then Luka had one just a couple of weeks back - worth asking him if he still has it!
by nitroman » Fri 04.11.2011, 21:58
That was it, BOTH dip-beam bulbs were burned out. Replaced them and everything works fine. I only put in those H1 55W +50% bulbs (in Cibie lamps) a couple of years ago, so I can say they really don't last that long. I have some 130W H1 bulbs I could have put in but I was afaid of either overloading something electrical or melting something plastic. Has anyone else ever installed 80W, 100W, or 130W headlamp bulbs in the M100? I did in my prior TR8 and they would melt the plastic inside the headlamp switch within about 2 months, but if I were to have used the headlamp switch as just a relay and run a 12V line directly from the alternator (the TR8 battery is far away back in the boot) to the headlamps it would have worked fine. Of course the TR8 lamp housings are aluminium and the headlamp body is metal & glass, so nothing in the vicinity of the hot bulb is subject to melting.
aka: Using these high output bulbs
http://shop.conrad-uk.com/1/2-a2-uk0852 ... -01b-.htmlinstead of the standard Osram 55W
http://shop.conrad-uk.com/1/2-a2-uk0852 ... ml?q=osramThey readily admit that a +50% brightness bulb also means 50% less bulb life. How they achieve +50% brightness without consuming more wattage is never explained though.
nitroman
by saska » Fri 04.11.2011, 22:56
nitroman wrote:They readily admit that a +50% brightness bulb also means 50% less bulb life. How they achieve +50% brightness without consuming more wattage is never explained though.
Up the resistance in the filament. Burns hotter, brighter and for less time before it fails.
Tony
adw (at) saska.co.uk
saska
by GeoffSmith » Sat 05.11.2011, 12:47
The resistance must remain the same (to keep the electrical power rating the same as Power = V² / R) so I think that they must use narrower gauge wire meaning the filament is shorter (R = ρ x l / A) and will get hotter, the higher the colour temperature and the more light is emitted (Stefan–Boltzmann law of blackbody radiation).
The hotter the filament, the shorter the life and more susceptible to overvoltage damage.
- Kitty Fiddler
by nitroman » Sun 06.11.2011, 01:31
Neither looked like a normal blackened burnt out bulb. The bulb glass was still crystal clear but the filament(s) reminded me of melted solder as there was a "melt ball" at one end in both cases. I've never had two bulbs burn out on the same night before. Like I said though, it was an 11-hour continuous lights-on drive, save for petrol & drainage stops (I have the 'ABC stack' to thank for keeping me awake)... so they both had plenty of time to build-up internal heat. It's weird they both lasted the entire night but were burned-out when I flicked on the switch two days later. Could have been that when I last switched them off that night the re-routing of electricity which uses the filaments as grounds was the final-straw for each of them.
It sure is a pisser changing them in that it takes several hours, especially if you choose to clean everything in the process. By that point I was ecstatic to find them both melted, as I'd already checked the controller, fuses, and relays!
nitroman
