bobbrown wrote:Hitting the speed bump may be coincidental, chances are one of the oil cooler hose has come off, as it did with mine and Spud has had the same thing happen along with others.
Driving the car with the oil pressure at or close to zero may not be a good thing to do even if it was only a mile, let’s just hope there is no damage to the engine.
SJ have oil cooler hoses listed along with the cooler it’s self but at a price.
If the picture is correct on SJ’s web site then the hoses do seem to have a better crimp on the connectors than the originals as it is these crimped ends that give rise to the problems.
The problems stem from pressure, vibration and hose shrinkage due to temperature changes or ageing all of which add up to cause the hose to become loose and finally pop off.
It should be possible to reattach the hose with a couple of “O” clips which are better than jubilee clips as the “ears” act a bit like a spring to compensate for changes in the diameter due to heat etc and it's probably a good idea to do the ends on both hoses.
Bob
