Head gasket failures - why so many?
Re: Head gasket failures - why so many?
Postby mmatthej1 » Mon 06.02.2012, 12:09
Thanks for all responses thus far; I've been in contact with a couple of fairly local specialist garages this morning and - whilst both suspect head gasket - it does seem possible that water loss is elsewhere, given that car is not overheating and performance is fine.
So, for the moment, suggestion is to top-up then run car around for a time (always making sure that water level is topped up), all the time scrutinising hoses and any othere conceivable leak point.
If water loss persists without explanation, then I'll take it in to one or other, so they can look it over and maybe 'sniff' water resevoir, for traces of exhaust gases.
Will update in due course and, again, thanks.
mmatthej1
Postby HJ2 » Mon 06.02.2012, 17:01
Why not 'snif' (block test) first, before driving around?
Not very expensive and tells a lot! Compression test also!
Good luck
Henk-Jan
Postby mmatthej1 » Thu 23.02.2012, 17:49
After taking a bit of time, to further observe and try to think of possible reasons for water loss (I tried adding the highly recommended K-Seal coolant additive, to no avail), I bit the bullet and had car looked at by my usual specialist garage, who rapidly tested & confirmed the dreaded head gasket failure - doh!
They reckon that age is the problem, having seen something of an upsurge of such failures in recent times. (~8 done by them)
I obviously don't like the diagnosis but have decided to get the job done professionaly by them, as I really don't like the look of the task from a 'do it myself' viewpoint - DIFM will cost but the job gets done to a specific timescale & assured quality, getting me back on the road with my knuckles & weak back intact, tho' with a lighter wallet!
mmatthej1
Postby drasicjazz » Tue 03.04.2012, 17:32
so after all ...where do I buy a good new gasket....
sj or rockauto?
or ...
thx
drasicjazz
Postby HJ2 » Tue 03.04.2012, 17:38
As per my tread:
I went for neither, but went fo OEM lotus.
Postby dapinky » Tue 03.04.2012, 23:08
I'd phone Steve at SJ's - they still list the Lotus part online click and when i got mine last year he had quite a few still in stock (Genuine OE Lotus ones).
Postby nitroman » Sat 07.04.2012, 00:44
IsuzuPerformance.com used to sell a full-copper head-gasket. It might be worth contacting him to see if he still has any. The worst he can do is insult you.
nitroman
Postby racerstev » Sat 07.04.2012, 05:12
If you want to go with a MLS gasket go here.
http://thomas4parts.com/specials.htm
You need some extra prep on the sealing surface's but you
will never blow another gasket..
Steve
racerstev
Postby drasicjazz » Sun 08.04.2012, 17:08
thanks for the replies. I did ring steven at SJ and he still has OEM gaskets.
i guess that seems like a fair option as I have not taken out the complete engine but only the head.
So i can only machine the head surface.
I do need to figure out how to clean my block dough, because there are lot of gasket flakes sticking on the block surface
any thoughts or products that devolve the gasket rests? :poke:
while the head is out i couldn't resist to reseat my valves and also port and polish my exhaust holes 8)
drasicjazz
Postby HJ2 » Sun 08.04.2012, 17:53
Cleaning:
I used a razor blade and skotch brite to finish it off :D
That looks like one organized work bench! 8)
Return to Engine
