bobbrown wrote:
Others may have different views on how to treat the rust and would be interesting to here others views.
Bob
I use the rustbuster products but the same basic proccess
remove loose / structurally unsound rust ( surface rust is ok to leave i.e. you don't need to get too fussy) - your typical 3 point paint scrapper is a very good tool for this - then wire brush / grinder etc.. ( if you have money and like tools then get one of these for rust bustin
http://www.qpaints.co.uk/mbx-abrading-tool.html)
degrease and de salt: probably one of the least done and most important parts - it's not for the grease you see, it's for the bit's that are imbebed in the rough surface finish of the parts - - - plenty products available as decent degreaser / detergents
wash off degreaser - yip the tub is now flowing
so apreciate you need all the carpets and stuff out
then I use a pre paint treatment - phosphate product as a surface rust stabaliser ( phos-Kleen-B for light to clean metal and fe-123 for parts that you can't easy get to)
then you paint it - first go round all the metal edges a wick a bead of paint along the edge - especially if you have two sheets of metal sandwiched together
once this is set then its x 2 coates of the Mastic 121 twin pack- - it's actually more like a coloured glue
now you can also water down the fe-123 and spray it into cavities - this is rust convertor stablaiser that forms a sealed skin over the stabalised rust - not sure if this is better than a cavity wax - it's an option
then you paint / spray cavity wax - and I use Dinitrol 3125 = seems to be well regarded stuff
the killers are using a porus top coat - std common paints - using a paint that is non flexable and chips and leaving tiny spots of grease / salt on the surface that will progress to rust spoting under your new top coat and happily eat away until finally a bubble appears that you can poke your finger through - -- and thin edge's that don't get an proper sealing top coat = induces flaking in from the edges
oh - and using hammerite = who obviously invest more in marketing bollocks than product testing
