epipete wrote:Do a bit, put it back together & enjoy the summer!!! The main worry I have is in regard to the outriggers (as pictured earlier), mine are like yours, this is the time bomb that is going to make all other restoration work redundant, and undermine the fabulous job you are doing!
The question is how best to address this problem.
Pete
norman lovie wrote:
One BIG recommendation ( i,ll remember next time)
sketch out a plan view of the shell identifying all the mounting points - include the lamp brackets etc..
now be carefull as you start removing bolts etc.. and lifting off the shell - note all the washers ( spacer's) - measure the overall thickness used - at each shimmed part - record this on the diagram for reference when you come to putting it back together
(OK, rant over)hatters wrote:Its a good job you are single because you would have an awful lot to answer for if you were married and your wife got hold of the receipts for all this NEW STUFF you have put on the car !!
Joking apart I think you are doing a grand job and thanks for posting all the photos and work descriptions its a great help to the rest of us on here
If you haven't yet changed the steering wheel beware ,I changed mine on my first M100 and used a puller to remove the old one but I only just managed it I was using so much torque on the puller I thought the steering column was going to come of its mountings before the wheel came off .It was extremely tight
