How to change your dial faces, comic style! (picture heavy!)
Re: How to change your dial faces, comic style! (picture hea
Postby cliff » Sat 21.01.2012, 23:24
Found this when I took mine apart:
Tried this:
Still have the bits but in the end didn't like it:
So went for this:
Metal Mickey will basically make you anything you want. All you need is patience and spoons
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby Giniw » Sat 11.08.2012, 13:49
Hello,
Interesting and well illustrated, thanks HJ2 =)
I have a little problem with my boost gauge. Its light does not work.
I removed the gauge and it appears that the white plastic is broken just like yours.
I will glue it too, but I am still wondering what is the proper way to remove the light. Should I pull on the black part on the rear or should I remove the needle and dial face — it could be a problem if I glue the front glass then!??
=> Do I have to just pull on the black plastic part? Or must it be rotated or something? I was unable to find any procedure relating to this in the service manual :(
Thanks in advance !
Giniw
Postby bobbrown » Sat 11.08.2012, 13:59
The lamp holders twist out and you need a capless bulb 2 watts I think
Bob
Pacific Blue N/A
bobbrown
Postby Giniw » Sat 11.08.2012, 14:18
Thanks!
(Twist like "unscrew" or just a little to loosen it?)
Giniw
Postby bobbrown » Sat 11.08.2012, 14:56
1/4 turn if memory cell is working
Pacific Blue N/A
bobbrown
Postby HJ2 » Sat 11.08.2012, 15:44
Correct! 1/4 left Bajonet-like fitting :-)
Mine are holding perfect!
Postby Giniw » Sun 12.08.2012, 03:18
Thank you =)
Giniw
Postby djcar » Sun 12.08.2012, 20:29
nice. can you post a pic of it it lit up @ night?
djcar
Postby Giniw » Sun 12.08.2012, 23:04
(I confirm that it was easy to extract the black lamp holder after turning it 1/4 turn! Thanks again ^^)
Giniw
Postby Giniw » Fri 17.08.2012, 22:42
bobbrown wrote:The lamp holders twist out and you need a capless bulb 2 watts I think
The replacement buld I found is only 1.2W, I hope it the good kind. I have not fitted or tested it yet.
Giniw
Postby HJ2 » Wed 11.03.2015, 08:45
... I see more pictures are hacked... Bugger!
Postby CalElan » Wed 26.08.2015, 01:00
great 'How to' and images - Thanks
CalElan
Return to Interior
