Piper Exhausts turbo downpipe development thread
Re: Piper Exhausts turbo downpipe development thread
Postby paulsmithmk » Mon 08.10.2012, 19:39
HJ2 wrote:No Boost creep?
Lucky you!
Wait for winter before you smoke the cigar...
As the air gets colder, it is getting denser and chances of experiencing boost creep increase.
As the air gets cooler the more she stays in the garage!!!
S2 Number 640
paulsmithmk
Postby HJ2 » Mon 08.10.2012, 20:00
Now there's an out of the box solution!
Haha
Postby ccb056 » Mon 15.10.2012, 04:34
Are there any temperature comparisons between the ceramic and non-coated down pipes? Perhaps Piper themselves could say how thick the ceramic coating is and how cooler the pipe is with it.
For 84 pound sterling (135 USD) I am not sure if a better deal for those in the US is to use Swain Tech ceramic coating on the Piper downpipe.
http://swaintech.com/advanced-coating-technology/
Swain Tech Coatings is the only company to offer a true insulating thermal barrier for exhaust parts. This external thermal barrier is applied approximately .012″ thick, has a white matte finish and does a tremendous job of keeping the heat inside of the pipes to improve scavenging and reduce under hood temperatures.
http://swaintech.com/race-coatings/auto ... ice-sheet/
Cast Iron Manifold (4, 6 or 8 cyl.) $150 – 235
Turbo Charger Housing $90 – 125
O2 Housing $50 – $100
Pipes, Down Pipe, Crossover, Collector, etc. $40/foot approx.
ccb056
Postby surfboardfiller » Mon 15.10.2012, 13:56
Ceramic coating on the inside (where it should be) was a lot cheaper. :wink:
I expect the GBP/USD exchange rate and usual higher prices here would lean in favour of getting it done locally in the US?
surfboardfiller
Postby paulsmithmk » Mon 29.10.2012, 20:26
OK so as you clever lot predicted got my first boost creep at the weekend - cold weather, revving through the gears and boom - fuel cut off, warning light on for about 30 seconds then back to normal and no repeat. So question - is porting the wastegate my only option?
S2 Number 640
paulsmithmk
Postby ccb056 » Mon 29.10.2012, 21:24
Either port the wastegate or restrict the flow through the exhaust.
ccb056
Postby surfboardfiller » Mon 29.10.2012, 22:45
ccb056 wrote:Either port the wastegate or restrict the flow through the exhaust.
Why would you restrict the flow through the exhaust? The whole point of the down pipe is to de restrict the flow through the exhaust to improve performance.
surfboardfiller
Postby rip » Tue 30.10.2012, 12:13
Another option is to be a little more cautious with the accelerator. That defeats the object too.
With an Everest chip, the variation between target boost & overboost is very small so you won't be likely to see it on the boost gauge..certainly not in time to react with your right foot.
An alternative is to go the 'plumbing route' which fools the ECU. This goes against upgrading it with the Everest so you wouldn't need it. I prefer the ECU to know what is going on & make the appropriate adjustments so do not like this method, although many have done this with their Elan with no issues.
This leaves porting the wastegate.
Postby paulsmithmk » Tue 30.10.2012, 13:09
or I guess only drive it on a warm day?!!
mmmm porting it will have to be I guess thanks guys
S2 Number 640
paulsmithmk
Postby Steve A » Tue 13.11.2012, 17:20
The only thing I need to do now is alter the short section of pipe from the Piper down pipe to the exhaust,
I will be adding a flexi to take some of the strain and vibration away from the Piper down pipe, it's probably
why my exhaust sheared in the first place
I've now done this, it's all on and running (photo's to follow), I feel much happier with a flexi in position it will help protect the down pipe.
Just got to live with it now and see how I get on, feels good so far :burnout:
Postby Steve A » Sat 02.03.2013, 18:57
Went for a blat in the cold air today :burnout: it was over boosting like a :censored:
and to make matters worse it happened whilst fending off a large 4X4 that fancied his chances :roll: :oops:
I was left eating his dust :smt104 FFS
Postby ccb056 » Sat 02.03.2013, 19:24
I'm starting to think the Piper PCE is a better choice than the Piper downpipe.....
ccb056
Postby HJ2 » Sat 02.03.2013, 20:04
Same here.
I finally hope that I can remove it next week and see what I can improve Flow-wise without a redesign of the whole thing.
Postby paulous » Sat 02.03.2013, 20:17
After reading this and other related threads I decided to go with the PCE. So I currently have a PCE and full 2.25 system with sport cat waiting to be fitted the week after next. I'm hoping I don't get any overboost issues. My car is an S2 but not chipped yet...altho considering a Kilimanjaro chip.
By the way does the piper tailpipe really fit? It's huge!! Nice tho.
S2 No.285... Then sold it 2014
paulous
Postby wayne » Sat 02.03.2013, 20:43
paulsmithmk wrote:OK so as you clever lot predicted got my first boost creep at the weekend - cold weather, revving through the gears and boom - fuel cut off, warning light on for about 30 seconds then back to normal and no repeat. So question - is porting the wastegate my only option?
Sounds like the Piper downpipe is doing it's job ..... Increasing the airflow....
How about getting Alan to review his mountain chip and raising the fuel cut off to more than 1 bar? would the stock injectors be able to deliver enough fuel? (or maybe upgrade fuel injectors to suit)?
Seems a waste getting all of this extra airflow to spin the turbo to just vent it off in a different direction?
Knowing nowt about turbochargers and airflow....... At some point in the near future I intend to change my downpipe for something along the lines of Steve Mathews pipe (I have found a company that will make it locally). As I know my precat has been previously cracked and repaired and the OEM downpipe and precat must weigh alot more than the piper downpipe. Has anyone weighed both parts? I currently have 2 1/4" exhaust aft of the precat with no boost creep with just a standard mountain chip.
I do have an old BBR kit laid around which would probably solve any overboost problem. But have never fitted it due to concerns about damaging the engine due to low air / fuel ratios.
Prior to fitting Alans Mountain chip. I previously used a MBC. I can conferm that with a stock exhaust and downpipe the Turbo can still produce more than 1 bar at way over 40C OAT.
http://www.elanm100.com
wayne
Postby GeoffSmith » Sat 02.03.2013, 20:58
Wayne, the cutoff is at its highest level (0.95 bar overpressure) as the stock MAP sensor only reads to 2 bar. There are equivalent 3 bar MAPs however. I think the stock injectors are pretty much maxed out as well.
Postby wayne » Sat 02.03.2013, 21:59
Oops, Sorry. ... Thank you for the reminder Geoff. I guess it's back to the 3 bar map sensor and 550cc injectors?
A bit off topic but. Does anyone still supply 3 bar map sensors that will plug into the existing wiring?
wayne
Postby Steve A » Sat 02.03.2013, 23:20
:? The question(s) for me now is:
Do I now have a car that is only good for when the temperature is warm :roll:
What can I try to improve the situation ?
Just to summarise :
Who is running the Piper Down-pipe and what is your set up and findings :
Steve A: 91 SE Turbo , 2inch Paul Matty exhaust , standard chip, waste gate ported to 20mm, over boost in cold weather , hot weather ??? generally hesitant when I put my foot down like it's holing back.
Postby rip » Sun 03.03.2013, 04:05
wayne wrote:Sounds like the Piper downpipe is doing it's job ..... Increasing the airflow....
I agree. It is working too well.
wayne wrote:How about getting Alan to review his mountain chip and raising the fuel cut off to more than 1 bar? would the stock injectors be able to deliver enough fuel? (or maybe upgrade fuel injectors to suit)?
As Geoff pointed out, the overboost cut is there because the injectors are close to their limit. Any higher & the stock injectors will not be able to deliver enough fuel. I doubt Alan will write a boost profile which he knows will cause the injectors to underfuel.
The injectors work by pulsing & maximum will be 100%. Larger injectors can deliver more per cycle but the ECU either needs to be modified to allow for the extra capacity or you would need to go down the 3bar MAP sensor route.
wayne wrote:Seems a waste getting all of this extra airflow to spin the turbo to just vent it off in a different direction?
& make the car harder to drive. You are boosting high because you want to go faster. The last thing you want to be doing is lift off. You'll then find an un-chipped Elan will have nipped past :(
wayne wrote:Knowing nowt about turbochargers and airflow.......
I think you underestimate yourself.
Postby ccb056 » Sun 03.03.2013, 04:53
I don't think the pipe is working too well. Because the wastegate flow isn't separated from the turbine flow, we are getting a lot of high pressure turbulent air directly downstream from the wategate port. This is causing less air to flow through the wastegate (something porting the wastegate can't fix).
To make the piper downpipe work well it would need to be modified with a baffle to keep the wastegate and turbine flow separate for some distance, much like the OEM and Knox downpipes have.
ccb056
Return to Exhaust
