….and pulled the rubber covers, removed the bolt at the right:
This allowed the fuse bracket to rotate to the right, and then the scuttle brace can be pulled around the control rod (see, I was taking care of it at this point ><) and removed out of the way.
The manual concentrates on the LHD and light was fading, so I just pulled the obvious 2 bolts securing it at the top, plus vacuum hose 1 from the microswitch:
At this point I had to use a bit of force to remove that earlier hose from the black actuator rear side:
And finally just remove the electrical guiding thing:
This frees the heater, assuming you've disconnected the coolant pipes in the engine bay. To get it out you also have to free the vacuum pipes from a couple of guides, one on the left (RHD) - and at this point you work out what the earlier instruction about the microswitch meant, and you can remove pipes 2 (visible) and 6 (curled round it) from the bottom, and side ports of the microswitch respectively. I did this later to my chagrin:
Theres another guide conduit on the RHS which I bent away, and you can also see the cluster of 4 pipes disappear behind the black actuator (arrowed). Not mentioned in the manual as far as I can see:
But here you can see clearly (and see the reverse port on the actuator where pipe X (CAN'T REMEMBER, UPDATE LATER, 3 POSS) came from) that they are trapped against the body, so loosening the lower screw arrowed, you can seperate the pipe cluster:
Finally pipes 2 and 6 were providing surprise resistance, so I pulled them. This is a good pic taken blind shoving the camera up there to show how they attach:
There was still corroded pipe/rubber debris at the other side, so I spent a bit of time destroying my fingernails pulling the old detritus off the other side. Eventually the rubber came loose so I could pull the heater from the cockpit. And then, disaster.
The unit needed a bit of wiggling to pull the copper pipes through from the engine bay, and despite the bracket marked in yellow technically preventing any impact to the temperature control rod, when the pipes came free, it jumped towards me and snapped the unobtanium rod:
So the worst of it is, now the heater is out, the pipes don't actually look too bad.
I might not have even needed to do this. I am absolutely kicking myself; in retrospect I would have rigged up some kind of cradle over a removed bonnet so I could have got my head into the back of the engine bay and examined more closely. I was convinced the pipes were rusty, but you will see in the next posts that the heater is actually fine, its got a tiny bit of corrosion to the ends of the pipes but its the rubber and hose clamps that were cancerous.
So I've broken the control rod C100P0086F, and cannot see one at SJs, DeRoure, or anywhere. Well, I tell a lie, there are two possible sources. One is something like lotusparts.it, which suspiciously came up with no stock information and allowed me to check out the E3.20 part with from what my Italian can muster, an E8 charge for minimum order, and E25 shipping, so just over 40 Euros after tax or about £33. I just checked out, maybe it will come through the post.
Alternatively you can see its threaded, maybe I can find some kind of joining piece that screws into both ends.
To cheer myself up I decided to see if the billet oil filler cap I'd bought from the States fitted. It did not.
However, I do now have the most INCREDIBLE gear knob you've ever seen, a late-night find from an Italian company specialising in custom parts for Abarths. So that, and the following pic console me a lot. Some may recall, I can't even find the post or the email from Bob Brown, but my heater only worked in positions 3 and 4 as I recall. You can see now its removed, that somebody at the factory never used the cable tie shown, and so one of the vacuum hoses was trapped and sealed under the heater. So perhaps if I can get a new rod, this won't all have been in vain as I'll tie the vacuum hose back properly or even replace it:
