Gear cables- no 5th or Reverse
Re: Gear cables- no 5th or Reverse
Postby Andy_J » Wed 17.04.2013, 21:12
Why don't you just take the Esprit Archie :lol: :lol: :lol:
90H BRG SE 48,000 Miles
Andy_J
Postby BigErch » Wed 17.04.2013, 21:34
Andy_J wrote:Why don't you just take the Esprit Archie :lol: :lol: :lol:
Hey! No fair!
BigErch
Postby BigErch » Mon 27.05.2013, 23:09
I've not had much luck with these AB cables so I decided to go back to the original cables and make up a bracket to clamp the sleeves in place.
Some of the other solutions involved bending sheet metal but unfortunately I don't have the equipment here to do a neat job.
All I did was weld a bolt onto the back of the gearshift bracket and make a flat plate with 2 slots and a hole for the new bolt.
Now I have all my gears and selecting is nice and smooth.
I also cut out 40mm from the gear stick length to give me a cheap short shift option. It looks like you'd need to turn down the end of the gear stick in a lathe before tapping it so cutting a section out was a lot easier.
BigErch
Postby Rambo » Tue 28.05.2013, 08:56
Should cut a few seconds of your drive to the Lecht summit with that short shift option Archie :burnout: :burnout:
Postby John_W » Tue 28.05.2013, 19:17
Archie,
Nice solution, and one that appeals to Aberdonian values. IE nice and cheap too. Glad you got it fixed in the end.
You say in earlier posts that the AB cables Stef sold you were stiff and you couldn't get them to work. The AB cables also require their own mounting bracket. Did Stef supply that to you when she sold you the cables? If not, ask her to post it up. The cables aren't much use without it.
Postby dapinky » Tue 28.05.2013, 19:25
John_W wrote:...... If not, ask her to post it up. The cables aren't much use without it.
I have to admit, when i passed cables to you, I ASSUMED you had the right bracket (it is slightly offset, compared to the SE one in your pic) and didn't include the one I have here - I can send it up if you need it....,
...that said, I like your 'temporary' solution, which may well become permanent as it seems to do the job - i'm even considering fitting a similar system to mine to prevent any future problems with the SE cables which are currently working fine......
Postby BigErch » Wed 29.05.2013, 09:16
Yeah, I got the bracket from Stef too. My original Lotus cables are only a few years old and their movement seemed much smoother than the AB cables.
I'm happy with the gears now, just got 2 rear wheel bearing to replace and a hispec rear caliper leak to fix :shock: and the car will be perfect. :burnout:
BigErch
Postby Rambo » Wed 29.05.2013, 19:42
Just in time for the Scottish summer :smt043 :smt043 :smt043 :smt043
Postby Andy_J » Wed 29.05.2013, 22:44
Scottish summer???? Whats that ????? :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Andy_J
Postby Jeemy » Wed 29.05.2013, 23:29
Don't. Just don't. I'm f*cking soaking. :bonk:
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby epipete » Wed 29.05.2013, 23:43
Andy_J wrote:Scottish summer???? Whats that ????? :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Much the same as an English summer but with more Scotch!!!
Postby BigErch » Wed 29.05.2013, 23:49
I'm hoping it stays dry tomorrow, meeting an Evora and an Elise in Tomintoul then it's a blast over the Lecht to Balmoral for photos beside the castle. This was the road that was closed with snow last week so anything might happen! :lol:
BigErch
Postby Andy_J » Thu 30.05.2013, 21:34
If you had the same weather as I did up here today, then I bet you have some stunning photo's and did it all with the roof off :burnout:
Andy_J
Postby BigErch » Thu 30.05.2013, 22:14
Weather was great...
BigErch
Postby Rambo » Thu 30.05.2013, 22:49
About time you traded up for an Evora Archie ;-)
