Electric Water Pump
Re: Electric Water Pump
Postby nitroman » Thu 18.08.2011, 20:12
Importec delivered the pump in a Bosch box with the Mercedes-Benz 000 835 69 64 part number prominently displayed. Armed with that I quicly found an even lower price, $62.29, at this site http://www.eurasiaparts.net/item/car-tr ... id=3703480 for the same Bosch part I got from Importec. Perhaps you can even do better with a little looking around.
If there is a Wiki part # xref for this "Auxiliary Water Pump" (as stated on the outside of box) the Mercedes-Benz # should likewise be included, with the same caveat about switching-over the Elan's impeller-cover. With Lotus no longer doing aftersales lists annually this kind of info is more important than ever, as their $450 price will no longer waver. Besides, I've only had one of these go bad on my three Elan's so I don't think it's a "buy on sale" part anyway.
For those who are comfortable only dealing with Rock Auto they do list Bosch 0130002070 for $90.79, although they show no applications for the part.
nitroman
Postby Exbury » Tue 18.10.2011, 18:03
Fitted the Vauxhall Omega water pump (cannot remember which one but think they are the same) to the Elan last year, garage said it fitted fine although they had to change the connector.
Exbury
Postby muley » Tue 18.10.2011, 19:40
Yes, the pre-facelift Omega has the same pump with a different connector - when I put a wanted out on findapart I got 3 replies and bought one for around £20, with a 3 month warranty.
1995 Palacio S2 no 507
Postby cliff » Sat 23.06.2012, 21:05
Ordered a pump from Amazon dot com for $61, $30 shipping, arrived within 5 days.
http://www.amazon.com/0008356964-75-91- ... f_pe_p_t_2
The plug needs to be fitted (a quick solder job), the pre stripped wires make it easy, they even supply 2 inline splices. The hose fittings are pretty much the same size as well.
91 Lotus Elan SE Turbo
07 Megane CC
06 Alfa Romeo Brera
cliff
Postby cliff » Sat 30.06.2012, 23:33
Because of the plug, the pump sits about 2" to the right (from the rear) compared to the old one. I fitted new hoses at the same time so not a problem for me but be advised. The Merc one I fould at the local scrappy was even worse.
07 Megane CC
06 Alfa Romeo Brera
cliff
Postby rmsmall » Thu 18.04.2013, 03:52
The pump is available on amazon for $56.32 at www.amazon.com/MTC-3033-Engine-Auxiliary-Water/dp/B0072JD842/ref=sr_1_2?s=automotive&ie=UTF8&qid=1366253236&sr=1-2&keywords=000-835-69-64. If this link does not work, do a search for 0008356964. It seems to be widely available but at different pricing - it is over $200 on Rockauto- but it's a Bosch.
My daughters let me drive once in a while!
rmsmall
Postby rdodger » Sat 20.08.2016, 14:00
Afternoon
What's the latest word on replacement pumps. Mine is shot.
I see SJS do a replacement. Is there anywhere else in the UK?
I can't really wait for one to turn up from the US as we are off to France in a couple of weeks.
rdodger
Postby Fredjohn » Sat 20.08.2016, 16:45
rdodger wrote:Afternoon
If you read the post at the top of page 3 of this thread, then put "Mercedes-Benz 000 835 69 64" into UK ebay, you might find yourself one pretty quickly and about half SJS price!
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby rdodger » Sat 20.08.2016, 18:02
The only ones I see are 2nd hand, I would rather have a new one to be honest.
rdodger
Postby rdodger » Sat 20.08.2016, 18:41
I'm thinking one of these. The dims look pretty much identical
http://www.ebay.co.uk/itm/BOSCH-univers ... SwcwhVOL03
rdodger
Postby rdodger » Fri 02.09.2016, 14:02
I'm just fitting my new bosch pump.
Can anyone confirm the brown wire from the original is + and the black -?
It might seem an odd question as I had assumed that to be so but the plug into the loom puts brown to black and black to black/white trace(possibly purple).
rdodger
Postby Fredjohn » Fri 02.09.2016, 17:01
According to wiring diagram, pump to earth is black and pump to relay (live feed) is black/slate.
Fans are black to earth, with a black/green feed.
Can't see a brown wire on the diagram at all except for 2 wires on the fan relay: black/brown and brown. The black/brown goes to a fuse becoming a black/red then going to the pump relay.
See wiring diagram below
waterpumpcircuit.doc
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby rdodger » Fri 02.09.2016, 18:04
That's great thanks.
rdodger
Postby raphsolo » Sat 24.09.2016, 05:55
Just to be sur, this electric pump is ok ?
Someone bought it ?
http://www.ebay.co.uk/itm/Bosch-additio ... SwSHZWcu1y
the plug are the good one ?
or this one :
http://www.ebay.com/itm/Auxiliary-Water ... 1831051230
Lotus Elan M100 turbo SE 1991 racing green - Lotus Elise S1 azur blue
raphsolo
Postby rdodger » Mon 26.09.2016, 10:21
The second one is identical to the original.
The first will work ok but you would need to change the plug I think
rdodger
Postby raphsolo » Mon 26.09.2016, 11:36
that was i thought !
so GO !
thank you :wink:
raphsolo
Postby KenS » Wed 01.11.2017, 22:12
After refilling the cooling system after changing the cam belt & main water pump, I had a slight leak from the impeller housing of the electric aux water pump. Took a gamble on ebay for a SLK/Vito pump
https://www.ebay.co.uk/itm/Water-Pump-OEM-Quality-Mercedes-Sprinter-Vito-V-Class-SLK-SL-E-Class-C-Class/400853776572?epid=1916916183&hash=item5d54bf38bc:g:MmcAAOSwYvFZMr1Y.
It fitted OK after I rotated the motor 90 degrees, and used standard automotive bullet type connectors to connect up. Runs OK, it has the benefit of magnetic coupling to the impeller, so there is no motor shaft seal to leak. Time will tell if its good quality.
S2 NMY #285
KenS
Postby Steve A » Sun 22.04.2018, 17:34
I know it's not been that long but hows this going or has anybody else tried this or anything else :poke: mine has died :cry:
Postby esprit888 » Sun 22.04.2018, 18:50
Steve A wrote:I know it's not been that long but hows this going or has anybody else tried this or anything else :poke: mine has died :cry:
I have a used one for sale if interested, 48,000 Km's
esprit888
Postby Jamie N » Sun 22.04.2018, 20:58
I have one here Steve, want me to fire it in the post?, free of charge of course. :D
Jamie N
Seal Wrangler
