Lucy
Share your pictures!
Moderators: theelanman, muley, Enright, algirdas, nitroman, clemo, dapinky, Nige, Dave Eds, Sy V, DaveT, Specky, Elanlover, GeoffSmith
Re: Lucy
Postby Ekapol » Mon 27.07.2009, 06:08
:mrgreen: I also see Canadian flags for some reasons. Optical illusion...
Ekapol
Re: Lucy
Postby Ekapol » Mon 30.05.2011, 00:04
Celebrating 100,000 miles :mrgreen:
I've just spent an afternoon detailing, polishing Lucy, applying the paint sealant too. She's never been shinier than this :-)
Ekapol
Re: Lucy
Postby DeanG » Tue 31.05.2011, 02:01
Nice. Soon I hope to at that mileage.
DeanG
Re: Lucy
Postby Ekapol » Fri 06.12.2013, 07:30
LGM strikes again!!!
Ekapol
Re: Lucy
Postby Ekapol » Fri 06.12.2013, 07:31
Ekapol
Re: Lucy
LGM in action!!! :mrgreen:
Ekapol
Re: Lucy
Postby HJ2 » Fri 06.12.2013, 11:54
Whoah! ... What's happening here?
Head conversion?
Re: Lucy
Postby Enright » Fri 06.12.2013, 13:23
HGF apparently, but opportunity to do a de-coke at the same time.
Nice & clean under there!
Re: Lucy
Postby HJ2 » Fri 06.12.2013, 13:49
I asked because of the studs :?:
Looks brand new!
Re: Lucy
Postby lotusgirlmarie » Fri 06.12.2013, 14:44
We try.
lotusgirlmarie
Goddess
Re: Lucy
Postby HJ2 » Fri 06.12.2013, 14:49
Do you leave the turbo in during HGJ ?
Re: Lucy
Postby lotusgirlmarie » Sat 07.12.2013, 05:43
Kinda. It's unbolted and moved away from the head.
lotusgirlmarie
Goddess
Re: Lucy
Postby tigerdog » Sat 07.12.2013, 20:59
Ekapol wrote:Image
Oh, so that's how you get to the oil filter...
I'm insanely jealous, you know Ekkers, that you live near LGM and have come into her good graces. I'm coming up on 6.5 years (but less than 10K mi) on the same timing belt and am a nervous nellie trying to find someone to replace it.
Re: Lucy
Postby lotusgirlmarie » Sun 08.12.2013, 06:44
It's also a great reference shot of the oil pressure idiot light sender and the oil pressure gauge sender. Not impossible to get to with the engine in situ but deffo not the easiest.
Timing belt is easy on this car. The big thing is to ensure that they don't skip a tooth as ekapol and I found the previous mechanics did. Also only use an OEM water pump. Have had a couple aftermarket go bad on my and it wasn't pretty.
lotusgirlmarie
Goddess
Re: Lucy
Postby tigerdog » Sun 08.12.2013, 16:53
lotusgirlmarie wrote:It's also a great reference shot of the oil pressure idiot light sender and the oil pressure gauge sender. Not impossible to get to with the engine in situ but deffo not the easiest.
I don't supposed you're headed to San Diego any time soon. Maybe a timing belt followed by a short vacation in a classic mid-century modern villa with pool, a short walk to the beach? :)
Re: Lucy
Postby lotusgirlmarie » Sun 08.12.2013, 17:28
Sadly I'm not down there anytime in Dec. It is a very tempting offer, though. Do you have a space to do it? You will need some things that I would not be able to bring. Either an electric impact gun rated for a minimum of 180ft/lbs of torque or an air compressor and tank, a hydraulic jack and jack stands and a suitable spot to do the do for a few hours. The other obvious bits too. Coolant, brakleen, red shop rags (Ekapol found out why they need to me red when we rebuilt his motor).
lotusgirlmarie
Goddess
Re: Lucy
Postby HJ2 » Sun 08.12.2013, 18:41
... So it won't show the blood stains? :-D
Re: Lucy
Postby tigerdog » Mon 09.12.2013, 23:04
Whoa! Even the very thought of a future possibility is the best offer I've had all month. Maybe in many months! I don't think there's a huge rush, Marie, since Smaug only gets about 1500 mi/year. I have an air compressor/tank good to 120PSI, enclosed garage, hydraulic floor jack + 4 jack stands and can arrange for just about anything else that's necessary. Maybe we should continue this discussion offline instead of hijacking Ekker's most exquisite photo thread.
Re: Lucy
Postby Ekapol » Tue 04.08.2015, 21:39
:burnout: :m100:
Ekapol
Re: Lucy
Postby tigerdog » Sun 23.08.2015, 15:53
Ekapol wrote::burnout: :m100:
Does this mean Lucy is once again out on the road, Ekapol?
Return to Picture Gallery
