epipete wrote:How to determine which cable is which (gearchange and crossgate).
Are the cables the same lengths (mine seem slightly different). If this is correct then which is which?
Various folk seem to have tied them to the existing cables and pulled them through from both the engine side and/or the cabin side - which is best?
Pete
epipete wrote:Aye , thanks. There is, I think, insufficient depth to clamp it to the bracket and still get a hold of the nut, I'll go and have a look.
but, admit it, there was room for some confusion in your earlier comment, that said, thanks for this and the pictures; so only 4 bolts to undo, eh? Hummmm! If you'd written a couple of minutes earlier you'd have saved me the cost of some (cheap) nut splitters
epipete wrote: Hummmm! If you'd written a couple of minutes earlier you'd have saved me the cost of some (cheap) nut splitters
) or do it cold?Return to Miscellaneous Problems - Need Help!
