Windscreen Corner Trim Blocks - All gone
Re: Windscreen Corner Trim Blocks - All gone
Postby novacaine » Tue 13.05.2014, 21:58
Anyone know if these are still available from somewhere?
novacaine
Postby inkitin » Wed 14.05.2014, 10:23
The last four additional ones I obtained from South West Lotus would have been more if they hadn't just sent some out to the States. I've since often wondered if that was Dave Bean replacing the ones I bought off them?? So you could try Dave Bean in the US.
Lotus said they had some more coming in, not long after I was finishing off this Group Buy, so they may now have some.
Finally you could try a ring around of Lotus dealers (I do know that Christopher Neil's keep a reasonable stock of M100 spares)
91 SE Calypso Red
inkitin
Postby Dave Eds » Wed 14.05.2014, 12:46
How many e you need? I have one spare.
'92 NM SE '90 Calypso SE now sold '10 Evora NA '62 Wolseley 1500
Location: High Cross, Herts or Mickleton, Gloucs or somewhere else
Postby novacaine » Wed 14.05.2014, 21:11
unfortunately I need two, both of mine are cracked but still there. I'll try the lotus dealers
novacaine
Postby inkitin » Wed 14.05.2014, 23:36
Just to make sure there isn't some confusion going on here! :?
Dave Eds wrote:How many e you need? I have one spare.
Dave, do you mean you have one block spare? (i.e. two corners) or one corner spare?
novacaine wrote:unfortunately I need two, both of mine are cracked but still there. I'll try the lotus dealers
Do you mean you need two blocks? (i.e. four corners) or do you need two corners? (i.e. one block!)
Just for clarity one car only needs one block because each block produces two corners.
So if Dave has one block and novacaine needs just two corners for the one car then problem solved methinks!!
Does this help?? :-)
91 SE Calypso Red
inkitin
Postby Brit-Car-Nut » Wed 14.05.2014, 23:56
According to the Lotus Parts Price Book, A100B0661F is officially obsolete as of January 7, 2011.
Lotus Manuals
Windscreen top corner spacer (where to find them)
Postby localad » Wed 11.06.2014, 16:53
Hi Guys and Girls, lovely Autoglass putting in my new windscreen cracked the new one in trying to adjust it and shock horror was using my old seals !!!!
so I have to wait another week for a new windscreen. I have noticed that the guy hasn't put back one of top corner spacers from my windscreen to the frame, it looks like a black plastic letter L, any idea where I can get these?
Many thanks
localad
Re: Windscreen top corner spacer (where to find them)
Postby novacaine » Wed 11.06.2014, 18:32
Unfortunately they are now obsolete, See the link below. There is a possibility we could start a group buy at so point, as long as there is enough interest
forum.lotuselancentral.com/viewtopic.php?f=85&t=23262&p=293199#p293199
novacaine
Postby Jamie N » Wed 11.06.2014, 22:11
Or make your own!, really not difficult, go round a scrapyard and you will find something that can be adapted and remember it does not have to be from that area on another car, check all over them for something that can be utilised, so much better when you make it yourself :D , cant remember the exact car I got mine from, quite possibly a Honda. :wink:
Jamie.
Jamie N
Seal God
Postby wayne » Wed 11.06.2014, 22:23
I have one sat in a box ready to be posted to Superbad.
He has offered to redraw it and make a STL file so as everyone can have them remade on a 3D printer via shapeways or otherwise.
http://www.elanm100.com
wayne
Postby Peter_W » Thu 12.06.2014, 21:55
In the meantime...one of my corner pieces is half gone, and on the other side a two inch section of the top windshield rubber is gone where it meets up with the corner piece. So today I filled in the gaps with layers of electrical tape, then a final layer over the top. The satin black tape matches the trim and corner pieces very well. I did this as a quick "proof of concept" but it looks so good I'm going to leave it in place. I used basic tape that was at the house http://m.homedepot.com/p/Commercial-Electric-3-4-in-x-30-ft-Vinyl-Carded-Electric-Tape-30002656/202712355 A Google search shows other tapes that are thicker and wider.
Peter_W
Postby Jeffbro » Tue 21.10.2014, 13:23
If anyone has an odd single side spare I would be grateful. One of mine is missing!
Don't mind making a donation!
Jeffbro
