basher wrote:I've just removed the sidelights/indicators from my Elan bumper ( which is also removed). They are both in reasonable condition but the inner silver surface is dull and a bit black in places so I wondered about replacement?
Any ideas appreciated.
mitreklov wrote:I had the same situation with one of my indicators, the silvering had deteriorated and the resulting illumination was poor.
I found these led panels on ebay and fitted them behind the lens. I used the existing bulb connection to connect them which means I can revert back to filament bulbs if I have to.
I also replaced the flasher unit with an electronic CF14 unit which cost around £6.50 from ebay.
The panels are very light and the indicator one is a perfect size to fit behind the lens. I held them in with some Butyl strip I had left over from a waterproofing exercise but you could just as easily use something like BluTac to hold them in place.
I'll see if I can find the links to the ebay items if anyone is interested in doing the same, they were dirt cheap.
It should be noted that these led panels have white LEDs which means if you have the remanufactured all clear lenses you'll need to find some yellow filter to colour them or find some panels with yellow LEDs to be usable as indicators.
Here's a few pictures:
Tim
Fredjohn wrote:The reason the lights were changed (side lights outside, indicators inside) was to meet C&U regs re the min/max distances from the edge of the car to the sidelights. Apparently early cars were built with indicators to the outside, then it was changed to meet the regs.
(Info courtesy the ever knowledgeable dapinky last Thursday!!!)
Tuga2112 wrote:does that mean if i flip then, my car will be illegal or fail the next MOT ?
dapinky wrote:Tuga2112 wrote:does that mean if i flip then, my car will be illegal or fail the next MOT ?
Not at all - Lotus reacted to badly drafted and wrongly interpreted legislation changes - either way round is legal in the UK (and probablyu anywhere else) - it was all to do with what is considered to be the 'outside edge' of the car, and the distance from that edge to specific light sources...
Users browsing this forum: AhrefsBot and 13 guests
