Vauxhall Senator/Carlton dashboard switch part numbers
Postby donsladek » Tue 04.07.2006, 20:12
Folks,
I bought a Vauxhall Senator heater switch panel on E-bay, and the switches that fit the Elan have the following GM part numbers:
Dual seat heater switch (2 yellow indicator lights)- 90213296
Heated rear window switch (1 yellow indicator light)- 90213287
Fog lamp switch (1 green indicator light) - 90213289
Rear fog lamp switch (1 yellow indicator light) - 90213292
Hazard warning switch - no GM numbers on the switch :?
Please note that the switch "paddles" are a bit shorter than ours, and that the symbols are in white rather than red.
Don
Don Sladek
Calypso Red '91 #37594
donsladek
Postby Dimitris_GR » Wed 13.09.2006, 10:20
That's because they are not the same. That also happens with the window switches.
So, they must come from another Opev/Vauxhall model and have the same length and color with ours.
Dimitris_GR
Re: Vauxhall Senator/Carlton dashboard switch part numbers
Postby GeoffSmith » Tue 30.09.2014, 20:22
More details on the Wiki.
