I need some advice guys, my passenger side door lock won't move down to the lock position, it feels jammed, I took the door apart ( found a bobbin lying in the bottom of the door and the metal plate hidden in the front of the door). The door will also not lock with the key, however the door will open with the internal door handle and the external door latch .
Central locking tries to lock when the fob button is pressed but I guess the lock position sensor is working as after locking two seconds later the driver"s side door unlocks. The alarm works fine.
Any opinion as to what is causing the problem - latch mechanism or actuator or bent rods out of position...or? If it is the actuator can I repair it?
Advice needed - how do I get the metal control rods out of the plastic pivot clips? Just force them until they part or break?
Is the effort of removing the glass ( and metal runner near the lock) worth it compared to removing the lock mechanism without removing the window? I do have one spare butterfly clip.
Putting all the control rods back - any advice? Should I lay in a stock of plastic pivot clips.
Here is a picture of my never before opened passenger door......before the fun started.
Many thanks
RIchard
