I've had my door panel off to fit a new door speaker and found these bits in the bottom of the door... everything seems to be working OK, particularly the window lift system since I cleaned off the 'cheddar cheese' and used a bit of new grease.
Thought I'd ask here and maybe get some peace of mind. I've replaced the butterfly clips and a door glass on an earlier Elan but so long ago I can't remember what I saw then so have been looking in the manuals as I couldn't see much inside the door through the access holes ...
Item (1) I can identify as part of the door lift 'butterfly clip' and the wing of the butterfly clip I could see in situ looked shiny and quite new but the other wing, if it's there, is hidden behind the window lift channel.
Item (2) is a short length of outer Bowden Cable & Item (3) looks like a cable tensioner.
Manuals are not very detailed but I think item (3) may be part of the 'Regulator Assembly' as the Parts Manual calls it (Section 11.02A Item 1). This appears to be the motor, cable and window lift channel all as a single part, i.e not serviceable or able to be dismantled. I'm sort of hoping that a previous owner had a butterfly clip and lifting cable break and had new ones fitted, and these are the bits that fell off when they broke.... can anybody help confirm that?
regards,
