Metal Monkey Dial Faces
Re: Metal Monkey Dial Faces
Postby Enright » Thu 04.06.2015, 18:32
My 2 Elans were built 3 months apart in 91 - one has a/c and a 6 position heater control, the other has (or rather HAD) a 4 position control and no a/c.
I felt the 4 position was a bit restrictive so if you look at this thread you can see that they now do pretty much the same, just without the a/c on one.
viewtopic.php?f=134&t=21436
Still no logic to how they seemed to come out of the factory though! :bonk:
Postby mitreklov » Thu 04.06.2015, 19:46
That's great info guys, thanks. I guess it is just another one of those quirky production run things that make our cars..... well quirky :)
I'll feed the info back to Naomi at Metal Monkey and suggest that if she were to add the 4 position version to the MM web site, the customer should have the option to pick the appropriate panel.
Thanks for the topic link, I wish I'd found this earlier.
Tim
In-between Elans right now
mitreklov
Return to Interior
