Drivetrain problems
by besidethewye » Mon 29.06.2015, 11:16
At last the Elan has let me down - en route to Scotland - floppy gear lever and stuck in second (which did enable me to get off the roundabout at least).
Looks like new cables needed. I've had a search around but am not 100% sure on what is available and what the recommendations would be. A bit disappointed that the car was just back from a service - suspect that the gear cables did not get looked at for some time.
Any advice on best approach and sources for replacements much appreciated.
besidethewye
by epipete » Mon 29.06.2015, 11:56
Speak/pm John (Brit car nut). He is now the guru making replacement cables.
viewtopic.php?f=48&t=22461#p302483
by rip » Mon 29.06.2015, 12:43
BCN cables will be cheaper, stronger & slicker than OEM ones.
Service schedules & MOTs don't cover everything so I would not expect this to be noticed.
by daveiow » Mon 29.06.2015, 13:43
with the above
Would add get the Short Shift Kit at the same time, tremendous improvement in shift quality.
"live long and prosper"
Evora n/a
Alfa Sud 1.5ti long gone!
daveiow
by besidethewye » Mon 29.06.2015, 14:13
Thanks for the advice.
What's entailed in the short shift kit? Would be nice to have a quicker gear shift - perhaps the fact that I instinctively went slowly through the changes should have told me the cables weren't great but I assumed it was a built in characteristic due to the front drive.
Same cables + some additions or is it different cables to start?
besidethewye
by daveiow » Mon 29.06.2015, 18:02
If you get the cables and SSK together BCN supplies slightly different rod ends and abutment brackets.
The shift isn't necessarily quicker, just more precise and "shorter", it feels like a modern car instead of the porridge stirrer we are all use to.
For the extra cost involved while you are doing the cables I think it is well worth it.
Evora n/a
daveiow
by Fredjohn » Mon 29.06.2015, 18:23
Get both the cables and the short shift from BCN. They work very well together and his cables are a huge improvement over std cables. The short shift has 3 different settings and you can choose when assembling how short you want it: I set mine in in the middle and am delighted with the resultant gear changing. Price is good compared to std cables too.
Thoroughly recommend this mod.
by besidethewye » Sun 02.08.2015, 09:14
Thanks all - new cables from BCN and short shift kit now in and working well. Certainly feels different!
besidethewye
