Perfect sense and so much neater.
epipete wrote:Velcro is a great fastener but the glue that sticks it to the door card/insert fails in the heat (I know, I have tried it!).
epipete wrote:What thickness of Ply did you use?
Tuga2112 wrote:epipete wrote:What thickness of Ply did you use?
Pete,
Ill let you know tomorow when i get home and start working on the brake again, ill measure the thickness of the leftovers I got from the job.
epipete wrote:I think the best way is to use fir tree connectors, my plan is to cut the correct plywood base, insert it loosely in the card, drill some holes through the ply and into the door card, then remove the ply, insert & glue some fir tree fasteners (that protrude beyond the ply) through the holes, cover the ply with leather (or whatever) and then press it back into the door card fixed through by the fir tree fasteners.
epipete wrote:Neil, I purchased some from Halfords the other day which I think are as you describe - the fir tree protrudes from the centre of a thin disc, a little over a penny diameter.
If I'm honest, it was Dave P who, I think, should take any due credit for this idea.
epipete wrote:My finished door! Still a small amount of fettling on the door card but otherwise very satisfied with my seamstressing!
