petrol filler
petrol filler
Postby Piperman » Tue 22.09.2015, 19:34
This question may have asked before , why does nt the petrol filler have a drain ? or is mine blocked? Derek
Re: petrol filler
Postby alan e » Tue 22.09.2015, 19:46
It has a drain like most yours is blocked
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Re: petrol filler
Postby Brit-Car-Nut » Tue 22.09.2015, 20:34
Re: petrol filler
Postby Piperman » Wed 23.09.2015, 04:39
its never drained i bailed it out in the wet! thanks Derek ;-)
Re: petrol filler
Postby rip » Wed 23.09.2015, 09:26
You should find the bottom end of this if you look under the car. Mine blocked at the elbow near the top, just below the drain hole.
You can try some compressed air from above but this did not work for me.
Re: petrol filler
Postby Jon » Sun 27.09.2015, 08:52
Just a word of warning - the drainage tube seems to perish, become brittle and crack....mine fell into several pieces upon touching it a few days ago....
P.s. Does anywhere know where the tube runs to after it goes through the bulk head round the fuel tank??
Jon
Re: petrol filler
Postby rip » Sun 27.09.2015, 20:34
Jon wrote:P.s. Does anywhere know where the tube runs to after it goes through the bulk head round the fuel tank??
Almost (but not quite) straight down. There is a pathway for it , honest.
Re: petrol filler
Postby donsladek » Fri 07.06.2019, 23:17
I've had some success with a thin strip of Scotchbrite pad, shaped into a "U", then pushing the legs into the inlet of the drain to act as a filter. It still stops draining over time, but when stopped up, I poke it a bit and it drains, and prevents larger debris from entering the drain system.
Don Sladek
Calypso Red '91 #37594
donsladek
Re: petrol filler
Postby dapinky » Sat 08.06.2019, 10:08
Don,
Another top tip from LEC - I never thought about making a filter .... just spend too much time clearing the pipe and clearing all the 'sludge' from the surrounding well whenever I notice it getting bad.
must go.... I've got to find the scotchbrite :D
