power steering removal
Postby stevo » Mon 30.05.2016, 16:43
hi all, am i right in thinking some of the early n/a cars had no power steering? im wondering about the practicality of removing the power steering from my elan and if it would mean changing the rack?
stevo
Re: power steering removal
Postby Candles » Mon 30.05.2016, 17:44
It would be easy to remove the pump and piping, but yes, you would need a new rack to enjoy the correct gear ratio for man-draulic rather than hydraulic, and hence more turns lock-to-lock. As most of us are so used to PAS cars, it will be quite a shock driving the car without: do you recall the days of not being able to turn the wheel when stopped? The steering effort required may also drown-out the excellent 'feel' we currently have.
Is Missy an S2? I can't remember. The S2 rack used to be available on aftersales and was a little bit better 'feel' so I put one of those in my car and I love it.
I presume this is to do with 'adding lightness'? If so, then I applaud it!
Candles.
Candles
Postby lotusflasherman » Mon 30.05.2016, 18:07
There is a manual rack in the Parts Manual. Manual is 2.96 turns lock to lock and powered is 2.74 so marginally different.
Your choice but I'd try removing the belt to see how heavy steering is when trying to park before I went too far down that route...
You might need to order some spinach ...
Postby Candles » Tue 31.05.2016, 06:54
I don't think you can deep fry spinach so Stevo would never eat it.
Candles
Postby GeoffSmith » Tue 31.05.2016, 09:34
Batter it first?
Postby lotusflasherman » Tue 31.05.2016, 11:02
What about with ketchup? :smt078
Return to Chassis & Steering
