John_W wrote:Nige and Muley ran BMW mini wheels: viewtopic.php?f=45&t=6774
rip wrote:Vauxhall 4 stud wheels are 4x100, but these have a +49 ET offset & the largest I have seen is 15". Bigger than this are usually 5 stud.
I have a photo of my Elan on my VX alloys while its own wheels were away for refurb.
dapinky wrote:The wheels fitted as 'standard' to Angies' Corsa SE are 4 x 100 PCD - 17" gloss black alloys with an ET of +44 - they come with 215/45/17 tyres - when she's not looking I may see how they go on the Elan![]()
One other thing to add to Phils informative post above is that the whole lot *may* change depending on the wheel width - the Elan OZ wheels are 6 1/2", but the S2 BBS are 7" (or I may be wrong on that, waiting to be corrected).....
.... if both have the same +60 offset, then the edges of the wheel will be in different places on the 2 cars (slightly more inboard on the S2)..... so if you fit a +52 offset wheel with a 7" width, the inner edge will be in the same place, but the outer edge will be outboard a bit - hence it *Should" clear the brakes still, but fill the arches up a bit better (purely aestetic!)
I don't know how this will affect the scrub radius, and it all gets confusing when wheel measurements use both inches and millimeters in the designation![]()
(Ignore the "J" bit of the width designation, that only refers to the profile of the tyre bead on the wheel and nowt to do with the actual width)
so I'll still be needing a bespoke kit.muley wrote:John_W wrote:Nige and Muley ran BMW mini wheels: viewtopic.php?f=45&t=6774
In actual fact, I never did.
John_W wrote:muley wrote:John_W wrote:Nige and Muley ran BMW mini wheels: viewtopic.php?f=45&t=6774
Sorry, Jim; my mistake.
When I swapped the Vauxhall type aftermarket 15" wheels previously on my car for a set of S2 16" wheels, I noticed a definite improvement in steering. Ie no tramlining or twitchiness on straights. The Vauxhall wheels look fairly similar to S2 wheels (they're on the Pacific Blue car in my garden on the banner header of the website home page http://www.lotuselancentral.com/index.htm , between Ben Weston's yellow S2 and Andrew Ennis's Medina S2) but had less -ve offset than Lotus originals. Getting the tracking adjusted might have improved things, but that would have been getting even further away from what Lotus designed.
__________
( Ruote SE )
)___ ___(
|<---->60
\ ___ ___
->---6.5---<-
__________
( BBS S2 )
)_____ _____(
|<---->60
\ _____ _____
<------7---->Users browsing this forum: No registered users and 0 guests
