Wiring diagram is on Sheet 8 of Section MJ of Service Notes.
Only fuse involved is 15 amp Fuse A17 (in passenger footwell) that feeds Wiper Motor, Wash/Wipe Switch, Intermittent Wipe Module, washer pump, washer warning relay, warning lights etc.. so if that fuse had gone nothing to do with wiping and washing would function at all. There is no separate fuse to do with pump.
There is a Screenwash Warning Lamp Relay that is "by the R/H rear lamp cluster (RHD)" with a relay coil that sits across the Screenwasher pump - haven't yet worked out the complete functionality but both pump & relay have a yellow/light green wire in common on the supply side and a black wire on the earth side. Suggest you check connections to pump and relay and where these wires join together as a bit of corrosion on a terminal might stop pump working but still initiate warning lamp relay.
If I get a chance I'll have a look at mine tomorrow with a multi-meter. The wiring diag shows an ignition supply to the Screenwash Warning lamp and that will only come on when an earth return is provided when the Screenwash Warning Lamp Relay pulls in, coincident with pump being energized, AND the Low Screen Wash Switch is closed. So the warning light should only show when you try to wash with low fluid level ... but mine gives me a warning light that is on permanently until I add fluid so need to investigate before I can comment further... the theory (diagram) doesn't fit the facts at the moment ..
