simonbuk wrote:Looks like a brilliant job !! So even the A- pillar seals are the cougar seals ?
simonbuk wrote:So what are the A pillar seals made from ?
Steve A wrote:simonbuk wrote:So what are the A pillar seals made from ?
The origin of the A pillar seal is not known, as it is similar to the Cougar seal I would have thought it came from a car with the same set up i.e. Glass closing against a seal without a surrounding frame, same as the Elan but a tin top.
lotusflasherman wrote:Steve A wrote:simonbuk wrote:So what are the A pillar seals made from ?
Subaru Forester and Impreza had frameless doors up to 2007 so glass closed against a seal. Was looking at my Forester's tailgate seal too..
lotusflasherman wrote:Forester front door window seals are only 20" to the right angled turn and looks like Elan needs about 23" on the A pillar. Better start looking for a Cougar....
chrisP wrote: I will be following your progress. Will your seal allow water to drain down the outside of the A-pillar or are you making it so that water doesn't even collect in the header rail? Also are you using a pair of Jamie's A-pillar seals to start with?
basher wrote:Hi Steve (Jamie)
It looks good and I'm going to have a bash myself. Just so I'm clear on this, you have put the Cougar seals on the header rail, which ones are you fitting to the leading edge of the hood?
thanks
Mike
thanks
Mike
