by simonbuk » Mon 20.03.2017, 20:51
I don't know about anybody else but the front number plate seems to be a bit flimsy in its fitting. I have a standard size plate which is screwed in near the top corners at either end. This makes it a bit wobbly a bit from top to bottom.
Is this standard fitment ?
I could cut my plate down as its a couple of characters shorter but then I would have to drill new holes leaving two to block up.
Other idea was to get a stick on plate but I'm sure theres not quite enough space to put it without going over one of the creases in the bodywork. Has anybody ever done this ? Did it look s**t ?
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by clemo » Mon 20.03.2017, 21:04
how many characters do you have and would this not leave drill holes visible ?
Also where does the plate sit . as in does the top of plate match up with top of the line running through the bumper or top of the plate line up with the bottom of the running line ?
If you are a few letters digits short old this not put more tension on the plate ?
I have seen vinyl plates on the bonnet similar to E type jag versions but it didn't look very nice at all .
From what remember the Elan was not designed with a number plate in mind ... not sure where i picked that up from .
i have also seen L shaped brackets coming of the lower part of the bottom mesh grill . They did this on the 2 eleven .
clemo
- LEC Administrator
by MPx » Mon 20.03.2017, 21:29
Mine is a standard size plate and stuck on using Halfrauds finest sticky fixers with the top edge lined up with the bottom of the bumper groove. It may flap about in the breeze, but I've never been aware of it (hard to see from inside the car!). Looks solid enough in this pic from Combe.
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
but no longer Carlton no 808 nor Sunbeam S1
MPx
by simonbuk » Mon 20.03.2017, 21:49
@Clemo - Yes in answer to your first two questions. Not sure what you mean by the third.
If I stickered it the bottom of the plate would sit in line with the top of the groove going through the bumper - so basically putting it directly above where it is now. Think it would then go over the line above also so yes, would look s**t.
Mine is positioned like the yellow one but holes very top corner.
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by Jamie N » Mon 20.03.2017, 21:57
On my old Pacific Blue I put a JDM style number plate plinth in black plastic and shaped the edges to conform with the shape of the bumper, it looked pretty good, and being an OEM part it didn't look like a modification. Similar type to this...
http://www.autolinkmx5.com/ekmps/shops/ ... 2550-p.jpg but it sat proud of the bumper about 30mm.
Another type is those Stainless steel "tilt" ones, now that would look like a mod!
Jamie N
- Seal God
by simonbuk » Mon 20.03.2017, 21:58
Zoom in on this -
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by Giniw » Mon 20.03.2017, 22:17
MPx > yours is not centered, is it? Maybe it's just the angle of the photo, though!
Giniw
by Rambo » Mon 20.03.2017, 23:28
Giniw wrote:MPx > yours is not centered, is it? Maybe it's just the angle of the photo, though!
It's stuck over a fraction too far to the right
- Don't push me
by GeoffSmith » Mon 20.03.2017, 23:40
Maybe it was centrifugal force on the Halfrauds sticky tape…
- Kitty Fiddler
by Giniw » Mon 20.03.2017, 23:43
lol
Giniw
by simonbuk » Tue 21.03.2017, 00:12
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by MPx » Tue 21.03.2017, 00:28
Hmmmm .... well spotted one and all - maybe I was having a Alfa Romeo envy day. I blame the cross eyed tw*t of a fitter and would strongly recommend that you don't use him - although the materials and methodology may have potential otherwise.
Mike - MPx
86 Turbo Esprit
MPx
by GeoffSmith » Tue 21.03.2017, 00:43
The look suits some cars better than others...
- Kitty Fiddler
by rip » Tue 21.03.2017, 01:07
Jamie N wrote:Another type is those Stainless steel "tilt" ones, now that would look like a mod!
"Revolving number plates, naturally. Valid in all countries."
by Rambo » Tue 21.03.2017, 09:30
Rambo wrote:Giniw wrote:MPx > yours is not centered, is it? Maybe it's just the angle of the photo, though!
It'll be further over to the right once we've been Brexited and you have to cut off the EU bit with the stars on the LHS. And then it will definitely be more Alfa Romeo'ish
PS and I've no doubt Geoff will show us when he drags himself off his sunlounger
- Don't push me
by Bern » Fri 24.03.2017, 12:45
My front plate is on a plinth. It's not a perfect fit, but it's not bad. Maybe it's from an MX5? I'll take a picture next time I see the Elan (it lives in my Parent's garage).
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
'80ish Kubota B5100E
Bern
by clemo » Fri 24.03.2017, 22:35
this is the 2 eleven style plate holder i was going on about
http://www.pistonheads.com/classifieds/ ... id=1&pid=2Willb's evora .
clemo
- LEC Administrator
by TrevorB » Fri 24.03.2017, 22:38
Minds held on by magic
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
- Wannabe Princess
by Rambo » Sat 25.03.2017, 01:17
Trevor - surely that's not a speck of dust or an imperfection in the paintwork on the bumper above the clear o/s lens ?? Shock, horror .........
- Don't push me
by Giniw » Sat 25.03.2017, 01:40
lol
Isn't it a garage door handle?
Giniw
