Collapso Notes 2016 on..
Postby muley » Wed 26.10.2016, 17:52
Got myself a project S2.
List of jobs :
1. Cambelt. Uncertain history
DONE
2. Wheels. Being round would be nice. Prefer not to have steel balance weights! Off to BJV Engineering.
DONE
3. Aux belts. Knackered. Prolly due to partly seized..
DONE
4. ..alternator. New one ready to instal
DONE
5. Oil change. Why not? Filter will be off for step (4) anyway.
DONE
6. OSR caliper. Excessive travel. Replace or refurb. Or Upgrade
7. Coolant change.
8. Tidy up under bonnet. It's a bit dirty partly because it needs ..
9. ..new CAS O rings. Already bought. Got lots in stock again!
10. Rad frame. Could use some paint.
11. Radiator. Why not, got a brand new one in stock.
12. Rad. fans. Cheap and easy while it's apart.
13. Window seals. Got to dismantle doors, though. Cheap enough.
14. Split in console.
Re: Collapso Notes 2016 on..
Postby Steve A » Wed 26.10.2016, 21:12
:D Should keep you busy in the winter months :wink:
steel balance weights! :wtf: :smt075 I once had a nice set of alloy's on my Westfield when it came to fitting the tyres
I just stopped the fitter in time as he was about to hammer on steel weights, ever since then I've become very wary :smt018
Postby Rambo » Thu 27.10.2016, 16:24
You could've come up and done all that sort of stuff on mine. And saved on the purchase price of an S2 :lol:
PS Has BFG in the BRG found a new home ?
Postby muley » Thu 27.10.2016, 18:30
Rambo wrote:You could've come up and done all that sort of stuff on mine. And saved on the purchase price of an S2 :lol:
No, not yet. Didn't sell on eBay so it looks like it will be going into storage.
Rgds
Postby clemo » Tue 01.11.2016, 14:38
Hope you enjoy your new toy Jim ..
When you get to do project 13 can you take some pictures .
Quite interested as to how this is done ..
ATB
clemo
clemo
Postby muley » Tue 01.11.2016, 17:05
clemo wrote:Hope you enjoy your new toy Jim ..
ATB
clemo
It's already been done. See https://www.youtube.com/watch?v=Xps5s0sbm3w
Top tip, don't use screws that are too long. :roll: l
Also Wienlot has done a good write up as well.
Postby dapinky » Tue 01.11.2016, 17:49
muley wrote:Top tip, don't use screws that are too long. :roll: l
Yep - if you follow the parts manual you will buy 1/2" screws - - - which are too long! (but fine if you add a M4 washer)
Postby muley » Wed 09.11.2016, 19:14
Wheels back from the geniuses at BJV Engineering.
Garage Queen
Postby Rambo » Thu 10.11.2016, 21:48
Think your near side headlight needs a bit of attention Jim :lol: :lol:
Never had you down as a Collapso Red sort of person :twisted:
Postby muley » Sat 24.12.2016, 16:49
List of jobs :
DONE
DONE
DONE
DONE
DONE
7. Coolant change. DONE
9. ..new CAS O rings. Already bought. Got lots in stock again! DONE
15. Transmission oil change. DONE. Special thanks (!) to the comic who previously used the filler hole as a a filler/level hole. :banghead:
All together and running OK apart from the flakey Cobra alarm.
Postby Rambo » Mon 26.12.2016, 12:06
Don't forget to order a headlamp motor repair kit from SJS Jim ;-) Or is it the headlamp pod module that's goosed ?
Postby muley » Mon 26.12.2016, 12:09
Hi Mark
No, it was raised manually so I could get to the bolt on the PAS pump. I have no problem getting an erection. ;)
Postby Rambo » Mon 26.12.2016, 12:15
Keep taking the blue pills and raising it manually :wink:
Postby muley » Tue 27.12.2016, 18:41
The thing is.. ..I only need quarter of a tablet these days. ;)
Have a good 2017.
See you at Silverstone.
Postby Rambo » Wed 28.12.2016, 10:01
Quarter of a pack of 12 more like :lol: :lol:
PS Silverstone a week later in 2017 due to F1 screw up :!: Knock on effect for the Classics :?
Postby muley » Thu 13.04.2017, 22:05
List of jobs :
DONE
DONE
DONE
DONE
DONE
DONE (replaced with recon. unit)
7. Coolant change.
DONE
DONE, well the front one anyway.
Postby muley » Fri 04.08.2017, 15:45
of jobs :
DONE
DONE
DONE
DONE
DONE
7. Coolant change.
DONE
DONE
15. Replace A post seals and header seal.
Postby muley » Sun 13.08.2017, 12:03
Seals off!
Postby Jamie N » Sun 13.08.2017, 17:27
They look amazing Jim!, well,,, amazingly shagged, (as they say in Glasgow) :D .
Monaco S2 #406
Jamie N
Seal God
Postby muley » Sun 13.08.2017, 20:19
Jamie N wrote:They look amazing Jim!, well,,, amazingly shagged, (as they say in Glasgow) :D .
Well, half of the seals fell apart like dust.. ..well shagged to put it mildly. No wonder it leaked.
