Glove Box Door Warped
Postby kevin31157 » Fri 16.06.2017, 15:40
GLove box.
Hi everyone AGAIN lol.
The door to my glovebox has warped somewhat and although it shuts ok you cant help but notice the gap around box and the door which i think looks terrible. Is this a common thing in the M100s and is it possible to get a decent one with key somewhere these days.
Thanks.
kevin31157
Re: GLOVE BOX DOOR WARPED
Postby Artaban » Fri 16.06.2017, 17:09
Are you sure its warped as the outside is just a shell which can come unglued from the rest of it. Pulling it apart enough to re-glue it sorted it for me.
Andy
Artaban
Postby tb10 » Fri 16.06.2017, 19:17
Artaban wrote:Are you sure its warped as the outside is just a shell which can come unglued from the rest of it. Pulling it apart enough to re-glue it sorted it for me.
Andy
tb10
Re: Glove Box Door Warped
Postby Dave Eds » Fri 16.06.2017, 22:27
Thread title volume dampened! :-D
Postby Simon_P » Sat 17.06.2017, 00:28
They've never been a good fit.
Even when you sort it out it will soon wander when you open it, and when you want to get behind it for some reason, it will be back to square one.....or not, as the case may be.
Postby kevin31157 » Sat 24.06.2017, 10:49
Ok thanks guys. I`ll take it apart and see if i can get it flat again with gluing it. Shame they`ve never been a good fit, it ruins the look of the dash when it sticks out from being flush.
thanks again.
kevin31157
Postby exeterjeep » Mon 26.06.2023, 15:08
I see this is a few years old, mine appears similar. Did glue the part that was detached, but remains banana shaped. One side worse than the other. Did anyone get this sorted?
A couple of pics to show how banana shaped it is. Even the centre looks a bit too far out as well.
Anyone tried somehow attaching a metal bar near the edge?
exeterjeep
Postby Giniw » Mon 26.06.2023, 23:04
I would say it looks a bit worse than mine, but I suspect they are all similar somehow.
That doesn't mean this cannot be sorted of course.
Giniw
Postby exeterjeep » Thu 13.07.2023, 09:51
Well have had a play with mine and after refitting it looks much better.
exeterjeep
Return to Interior
