dapinky wrote:Joao,
If you are replacing the bolts, note that the inner and outer ones are different lengths - so you will need 2 x M8x70 & 2 x M8x85........
....also, make sure that they are HT bolts (10.9 minimum, but 12.9 are better) - NOT 'standard' HT bolts of 8.8 rating.
Usually, hex headed bolts are 8.8, and the higher strengths are allen headed bolts. (but you can get any configuration if you look hard enough and/or get them made).
Something like
thesewill be good or
these(and if you can't find 85mm ones, then 80 will probably do)
Thanks Dave,
I did notice there was 2 different sizes.
I became aware higher tensile strenght bolts are "always" hex/allen key ones when i was in a pickle with the bolts for the front caliper. (remember ?
I have now packed up for today. good progress i think, although any garage owner would probably tell me to find a career elsewhere.
So far i have managed to
remove the underframe. (will be giving it a good clean at some point before going back in. )
remove both driveshafts (one came out easily using a crowbar and hammer, the one on the side of the transmission i used a ball joint splitter (fork) and also managed to get it out.
jackshaft is out (by far the easiest task of the day)
downpipe is loose, and i also removed one of the rubber mountings so that it can move further down.
I did not release the anti roll bar, as from the manual, its suposed to come out to allow the downpipe to move freely, but since its not in the way, i think its a missprint.
what i need help with at the moment is actually to know "
where" to put the floor jack to hold the engine/transmission before starting to undo the left and rear engine mounts.
looking at it it seems like the only suitable places are to hold the transmission itself. but then after taking the transmission out i would have the engine being held by a single mount which sounds very wrong.
apart from that, i need to investigate where are exactly all the bolts that i need to remove in the next few steps. but i suspect there is enough information out there about it already.
