New Front rubber lip and fixings
Postby Stef » Tue 29.08.2017, 15:07
Blipi is finally going off for a long awaited paint job and I need to replace the front rubber lip.
Things change all the time so could I please as best place for the rubber, what are the best fittings & where to get along with any best advice?
I'm not a big fan of SJ's after they ripped me off but they have a rubber lip £16.75 SJ100B0011 & Kit of which I don't know what is included as picture shows something else £9.89 SJ100B0018
Have there been any LEC created parts??
I've not looked myself underneath however suspect I have original fittings that are likely to be crusted on!
Many thanks :)
Stef
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Re: New Front rubber lip and fixings
Postby lotustonybassplayer » Tue 29.08.2017, 15:30
If you look Toby's videos on the m100 restoration channel on youtube the details, of howto and part supply are on one of the videos :D
lotustonybassplayer
Postby theelanman » Tue 29.08.2017, 15:31
looks fine to me.....
altho I hope the pic of the fitting kit is wrong......(it shows the b post hood flap/cover)
Postby Giniw » Tue 29.08.2017, 15:49
I ordered two rubber lips at SJ a couple years ago and it was OK.
If I remember correctly it is directly available at walker rubber, which is the supplier, so it's probably a bit cheaper if you order directly from them.
Maybe SJ100B0018 is the three plates that fit underneath? Definitely not the right photo indeed.
Anyway, as for the plates, if you need to make them yourself I drew a SVG pattern (over someone's handmade drawing scan available somewhere here) and then made a scale PNG easy to print on a A4 paper (just print it at 300 dpi and it should be OK — I included two bars to check if the printing is OK). You then just have to glue the parts properly to have a full scale pattern to cut out of your favourite material:
front: https://www.mirari.fr/dUlg.png
side: https://www.mirari.fr/S01X.png
Giniw
Postby alan e » Tue 29.08.2017, 19:21
Stef if you go on youtube look for Replacing the rubber trim on the front bumper of the Lotus Elan M100 Toby will show you where to get the rubber trim and what fixings you need and also where to get them once you remove the old rubber its a easy job to replace it done mine with the bumper off the car which I think is the way to go if the bumper is being removed for the paint job if not its still doable with it on.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby clemo » Tue 29.08.2017, 19:49
Stef ,
Walker rubber was the people who made them originally .
May be worth trying to get one from them ?
clemo
Postby muley » Tue 29.08.2017, 20:17
I've replaced the lips a few times and instead of using the plates just used penny washers
Postby lotusflasherman » Tue 29.08.2017, 23:32
muley wrote:I've replaced the lips a few times and instead of using the plates just used penny washers
:clap: Adding Lightness Jim.
Postby Stef » Wed 30.08.2017, 11:23
Many thanks! Most helpful :)
Looks like the clip and washer approach is easiest, the SJ listing 'i' information tab describes washers & clips.
For ease of reference, here is the youtube link: https://www.youtube.com/watch?v=ej7HMku2auA
It's under 4 min and straight forward.
Stef
Postby theelanman » Wed 30.08.2017, 11:58
Stef wrote:Many thanks! Most helpful :)
when youve got a man to do it.....
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Postby muley » Wed 30.08.2017, 12:02
..and money saved. When you're on a pension ya de ya...
Postby muley » Wed 30.08.2017, 12:22
:lol: Did you miss the bit about the 2 hours of swearing, cursing drilling, grinding, fibreglass repair to get the old ones off?
Postby Stef » Thu 31.08.2017, 21:13
The video is under 4 mins!!! And, yes, I do have someone else to fit it, all under the respray job :)
Stef
Postby Rambo » Fri 01.09.2017, 09:21
Postby muley » Tue 14.08.2018, 18:35
One hour into the 4 minute job!
Postby Rambo » Tue 14.08.2018, 19:01
Angle grinder and mole grips. Precision surgery :lol:
Postby muley » Tue 14.08.2018, 19:17
Probably worth mentioning that my S2 did not have 'boomerang pieces' and I'm fairly sure it left the factory like that. Well, judging by the rust. ;)
Postby muley » Tue 14.08.2018, 19:18
Rambo wrote:Angle grinder and mole grips. Precision surgery :lol:
New hip, anyone?
Postby John_W » Tue 14.08.2018, 19:19
Re-fitting is the reverse of removal, but without the angle grinder.
:chair:
Postby clemo » Tue 14.08.2018, 19:27
muley wrote:Probably worth mentioning that my S2 did not have 'boomerang pieces' and I'm fairly sure it left the factory like that. Well, judging by the rust. ;)
Would there be any advantage to putting them on the S2 ?
From what i understand they dropped this plastic boomerang pieces on the S2.
clemo
