Project Black Minor........bits......and pieces......
Re: Project Black Minor........bits......and pieces......
Postby simonbuk » Mon 11.09.2017, 17:07
Seals in place on windscreen and hood, waiting for the butyl to arrive which will hopefully be tomorrow. Small amount of adjustment to make but the April showers keep delaying play !!
The only issue I had was whilst pushing/pulling the car in and out the garage the steering wheel must have turned slightly. Pushed the car into the side wall - :oops: :oops: :banghead: :banghead: :bonk: :bonk: :oops: :oops:
I remained remarkably calm and I'm sure a quick visit to Chipsaway will have it sorted.
I'm so happy to have the old sponge holes things off the roof I don't mind the extra cost !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Jamie N » Mon 11.09.2017, 17:35
simonbuk wrote:Pushed the car into the side wall -
Woops! :? , let us see how bad it is then, a bit 1500 grade and Farecla G10 might be all it needs.
Monaco S2 #406
Jamie N
Seal God
Postby simonbuk » Wed 13.09.2017, 17:26
Managed to touch 3 different panels !! All scuffed and go through the paint to differet degrees. I think one might polish up/out a bit.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Jamie N » Wed 13.09.2017, 21:17
Doesn't look too bad Simon. Get the proper colour and a fine brush, fill the scratches to level and leave for a week or so, tiny bit of 1500 grade wet n dry and soapy water , then polish... Should be virtually invisible. :wink:
Monaco S2 #406
Jamie N
Seal God
Postby simonbuk » Sun 17.09.2017, 13:07
Combined A pillar and header seal now all fitted - much neater - no more Sugru needed. ;)
Also bought these new indicator stalks, had them on a TVR before. The only problem now is driving the car enough to remember which stalk does what !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Saltire » Sun 17.09.2017, 18:27
Looking good, Simon. And your windscreen corner pieces look to be in excellent condition - much better than mine :clap:
Postby simonbuk » Mon 18.09.2017, 19:19
Having now driven the car with the indicator stalks on, i find that they are actually quite slippery, your fingers tend to slip off them a bit unless you are quite firm in your actions.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
