New guy here
New guy here
Postby Andrew D » Mon 30.10.2017, 08:42
Hi,
I’m new to the forum. Recently bought an SE which I’m thrilled with however............there are problems with the drivers (RHD) window lift and seals. Any advice available?
Thanks,
Andrew D.
Great Dunmow, Essex.
Home of the Flitch.
Andrew D
Re: New guy here
Postby rip » Mon 30.10.2017, 09:59
Andrew D wrote:Hi,
Thanks,
Andrew D.
Home of the Flitch.
Welcome.
I don't have the answer but you would be better off asking this in an appropriate forum where it can be more easily found by anyone a) with a similar issue b) who has a solution available or 3) who may have a spare part which would be useful.
If I had a problem with my windows, I would not start by looking through the new members section.
Re: New guy here
Postby Fredjohn » Mon 30.10.2017, 12:48
rip wrote:
Andrew D wrote:Hi,
Thanks,
Andrew D.
Home of the Flitch.
Welcome.
To be slightly more helpful (get up the wrong side of the bed Ian?) try posting this in the relevant section of THIS forum or indeed searching the forum for window issues. I expect there are several posts which will help. Alternatively a moderator may move your post to the correct area of the forum.
Having said that welcome to LEC: it is a friendly site, with much useful help and knowledge: there aren't many issues not covered somewhere. Start by reading the WikiLEC (tab at top) section which hosts many good tips and info. Check out your local area meetings too: also located somewhere on here.
And all newbies are absolutely totally completely obliged to post photos of their pride and joy!!!!!! :D :D (your car that is!) Look forward to seeing them.
Elan S4 DHC 1969
Evora 2010
MB CLK 320CDi 2007
Swift Sundance Lifestyle 500
Re: New guy here
Postby Steve A » Mon 30.10.2017, 13:11
Andrew D wrote:Hi,
Thanks,
Andrew D.
Home of the Flitch.
Nice to have a new member especially from Essex 8)
The forum has many helpful members as well as an excellent search facility :wink:
Re: New guy here
Postby Dave Eds » Mon 30.10.2017, 13:56
Welcome Andrew. I'm not far from you so shout up if you need help and advice.
I've split your post from the other new member's topic, and relocated it so that Iain can take off his grumpy hat and get back in his box.
'92 NM SE '90 Calypso SE now sold '62 Wolseley 1500
Location: High Cross, Herts or Mickleton, Gloucs or somewhere else
Re: New guy here
Postby rip » Mon 30.10.2017, 14:14
I didn't intend to be grumpy.
Maybe I should suspend myself for a couple of days? :-D
Re: New guy here
Postby Dave Eds » Mon 30.10.2017, 14:21
rip wrote:I didn't intend to be grumpy.
I can ban you completely if you'd like me to! :chair:
Re: New guy here
Postby Fredjohn » Mon 30.10.2017, 14:22
No just go for a long healthy bike ride and we'll let you off.
:-D :-D :-D :-D
Elan S4 DHC 1969
Evora 2010
MB CLK 320CDi 2007
Re: New guy here
Postby John_W » Mon 30.10.2017, 18:54
I did that at the weekend in Aviemore using a hired bike, and my arse is still sore.
:evil:
Re: New guy here
Postby DavidS2 » Tue 31.10.2017, 12:50
Hey Andrew,
Welcome to the wonderful World of Elan ownership !
Cheers...David
Cheers .. David
Current: 1994 Elan S2 (131)
Past: 1995 Elan S2 (378)
DavidS2
Re: New guy here
Postby Jamie N » Tue 31.10.2017, 19:22
Andrew D wrote: problems with the drivers (RHD) window lift and seals. Any advice available?
Get it in a watertight and dry garage over Winter or a cover of any sort, leaking Elans rot from the inside out, check the "outriggers", plenty on here about them.
Welcome aboard the board Andrew. ;-)
Jamie N
Seal God
Re: New guy here
Postby Brit-Car-Nut » Tue 31.10.2017, 23:03
Andrew D wrote:Hi,
Thanks,
Andrew D.
Home of the Flitch.
Welcome to LEC!
For your window question, you can look at Specky's write-up: http://www.lotusm100.com/manuals/Window ... 0Guide.pdf
It starts with a fault chart and then has the step by step guide to disassemble and reassemble the door components.
It originally had a few videos but the storage he used changed their policy and they are no longer available. I had grabbed the pictures, so they are in the PDF, but never grabbed the videos.
I hope this helps you fix your problem.
You could also post your specific problem and symptoms and someone will probably jump in and make some suggestions.
Lotus Manuals
Re: New guy here
Postby CalElan » Fri 03.11.2017, 00:30
this is a good video of how to get into the doors:
https://www.youtube.com/watch?v=Xps5s0sbm3w
CalElan
Re: New guy here
Postby basher » Thu 09.11.2017, 23:43
Welcome Andrew,
Good to see another Essex Elan owner.
basher
Re: New guy here
Postby epipete » Fri 10.11.2017, 09:24
And RIP's one of the good guys ;-)
:lol: :lol: :lol: :lol: :lol:
Re: New guy here
Postby Andrew D » Sun 12.11.2017, 17:53
Thank's for all the advice and comments.
Fortunately I'm in touch with a local garage I have known for years and they look after two other M100's for another local owner.
As requested, I'm attaching some photos. The maroon Daimler in the background of one of the shots is my SP250 (Dart).
Fibre glass rules OK!
Andrew D
Re: New guy here
Postby tigerdog » Sun 24.12.2017, 05:50
:smt023
Return to Doors and Windows
