), but a lot of modern batteries are sealed or have no Vent Tube. Just avoid causing sparks after the battery has been charging...lotusflasherman wrote:It's the Battery Vent Pipe (A100M4997K). If your battery has a Vent Tube it should be connected as battery charging produces hydrogen (), but a lot of modern batteries are sealed or have no Vent Tube. Just avoid causing sparks after the battery has been charging...
Kipperozzy wrote:lotusflasherman wrote:It's the Battery Vent Pipe (A100M4997K). If your battery has a Vent Tube it should be connected as battery charging produces hydrogen (), but a lot of modern batteries are sealed or have no Vent Tube. Just avoid causing sparks after the battery has been charging...
I remember jump starting my pals Capri when we were teenagers, connected the cables in the wrong sequence, blew the top right off my battery, we looked for it after I stuck my head in a trough of water and it had gone.
Thankfully only my boiler suit got acid burns .
40 years later and I stil shudder when jump starting, but use the engine block as the last connection now !
Rambo wrote:Kipperozzy wrote:lotusflasherman wrote:It's the Battery Vent Pipe (A100M4997K). If your battery has a Vent Tube it should be connected as battery charging produces hydrogen (), but a lot of modern batteries are sealed or have no Vent Tube. Just avoid causing sparks after the battery has been charging...
Kippered Ozzy. Well named
Jamie N wrote: Aye, sounds like you have become a bit Paranoid.
lotusflasherman wrote:Jamie N wrote: Aye, sounds like you have become a bit Paranoid.
You've obviously never experienced a battery explosion then. Don't think I'm paranoid, just been there, got the T shirt ...
Jamie N wrote:....... maybe only the Heavy Rocker's among us will "get it".
dapinky wrote:Jamie N wrote:....... maybe only the Heavy Rocker's among us will "get it".
I got it, but as today is Black Friday, not Sunday, I'm giving no clues to the rest of 'em.
rip wrote:Black Friday is next week.
Rambo wrote:Am I going insane ?
I thought this was about drainage tubes
Brit-Car-Nut wrote:Rambo wrote:Am I going insane ?
Blame Jamie N for being so paranoid
dapinky wrote:Don't bite his head off!
