par wrote:It is called Inner Door Trim Top Strip B100B0845F & B100B0846F (right & left hand side).
Your picture doesn't actually look too bad, they are very flexible so don't hold a rigid profile very well and may get just as good results by fettling with the fit of your originals. If you do want to go with new parts they are under £10 each in the UK
chrisP wrote:Hi Par, where are they available from? - I was looking for ages, I found the shorter S2 versions but not the longer S1 versions.
Brit-Car-Nut wrote:chrisP wrote:Hi Par, where are they available from? - I was looking for ages, I found the shorter S2 versions but not the longer S1 versions.
The S1/SE version A100B0845F and A100B0846F are no longer available.
The S2 versions B100B0845F and B100B0846F are now offered from places like SJs since they also went obsolete at Lotus in December of 2015 for the Left side and December 2016 for the Right side.
Brit-Car-Nut wrote:Unfortunately, they will be a bit shorter than the originals.
ElanBRG wrote:Brit-Car-Nut wrote:Unfortunately, they will be a bit shorter than the originals.
Darn!
