basher wrote:As per the request further back, please feel free to use my outrigger repair photos in any way you wish if you feel the need.
Best of luck with the project Neil, it might be worth sticking a camera into the outrigger cavity to see what it looks like inside.
Steve A wrote::agree:
At the very least anybody who hasn't got closed cell foam should replace the old stuff as it holds the water.
chrisP wrote:The rust doesn't look too terrible, what is it like inside the cill? I would treat and paint at that stage and if it was any worse and I would replace. I do not like the idea of plating over, as you are just creating a hidden problem.
John_W wrote:1 sq m if you follow Enright’s template earlier in this thread:
viewtopic.php?f=30&t=17298&p=313027&hilit=Foam#p313027
I would go for double the thickness of foam, as there’s plenty of space available, or just get 2 sq m and put two layers. It weighs nothing so you’re not adding weight.
John_W wrote:Just think how it’s adding to your c.v.!
If that stuff you link to is self-adhesive, that would be good, however because it’s only 50cm wide, you won’t be able to make use of Enright’s clever topological trick, so will need more than 1 sq m.
