, but if you want to go down the Honda
Jamie N wrote:Kenny, you can get a pair from a 3 door Honda HRV for about a fiver in a breakers yard, a 2001 Civic coupe also, and with a small
bit of fettling with the curvature you will then have probably the best alternative solution available.
They hold the glass a lot more firmly as it closes onto the seals, the surface finish is high quality and doesn't crack
in multiple places all along as the originals do, no messing about with sealant either, and the way the retaining tabs connect
to the weather strips and onto the door is second to none.
If you search 'Steve A' and 'Par' posts you will see some more details on how they done their ones, and here is a picture of mine, done
correctly you wont find anything neater.
There is an end cap which comes with the strips, removed in the picture to show the profile, they are constructed with stainless
steel so wont rust either. Fit these once and that's the weather strips sorted for good, and for how much!, less than the price
of a tube of black death Sikaflex, Its a no-brainer!.
Jamie N wrote:The pressure of the strip against the glass, if you look at the open end you will see a rubber lip which points upwards,pretty much the norm for weather strips on modern cars, glass + rubber + a little pressure = watertight.
Elanlover wrote:Grrrr……
The HR-V wasn't sold in North America until 2016 and only in 5 door versions. So no luck there. Also, it's looking like the Civic Coupe may be different here than in the UK as every parts diagram I have come across doesn't show the door trim piece as separate and distinct from the door itself and a call to my not-so-friendly local Honda dealership resulted in them trying to sell me window tape. They didn't have a clue what I was talking about. Anyone have any suggestions or alternate sources for this piece?
Elanlover wrote:I'm actually interested in following Jamie's method. My preference would be to source new ones from a dealer if possible.
