burble61 wrote: So an appropriate micro-insert could well do the trick, something on the lines of
https://www.insertsdirect.com/acatalog/Packs-of-100-F4-2R-Pressfit-Inserts.html might do (with care on selection of materials to prevent galvanic corrosion between insert & screw). Possibly the best approach would be a blind/flanged version (blind to stop the epoxy coming up the thread hole during fitting & flanged to limit the depth). I would have to build up courage before drilling out the holes with my level of practical skills though, given the potential for going right through the door skin...
i really like that idea. i was no aware such thing existed.
as far as driling the holes, its a dangerous task, but using sharp drill bits and going in very patiently with mild pressure on the drill, you will be able to easily stop applying pressure before the bit reaches the second sheet of fibreglass.
im going to do a bit more reseach on this micro inserts.
I did fix the yellow car 2-3 weeks ago, by just using the self tapper screws. i dont like them and they dont feel like a permanent solution.
i may look into stainless setup on both bolt and insert. which should be a hassle free fix, while allowing me to remove them easily when i get things ready to paint again
i started looking into the suggestion and foudn these
https://www.ebay.co.uk/itm/THREADED-BRASS-INSERTS-SLOTTED-SELF-TAPPING-KNURLED-PRESS-FIT-M3-M4-M5-M6-M8-M10/202304125116?hash=item2f1a43f8bc:m:m2vTvcMUebpvJR3P88otiCAi was thinking these could do the job nicely, if i put epoxy part A in the insert and part B in the hole.
is this what you had in mind ?
brass may not be a good material as it corrodes with both zink plating on bolts and stainless steel.
with that in mind, i could try some grease i guess or possibly locktite ?
