Headlamp Pod Motor
Headlamp Pod Motor
Postby Bagwich » Fri 11.01.2019, 15:07
I am trying to acquire a nearside/left hand headlamp motor for a 1995 Lotus Elan S2. It will need to be posted to the Isle of Wight.
Can anyone assist??
Many thanks
Bagwich
Re: Headlamp Pod Motor
Postby Rambo » Fri 11.01.2019, 16:57
Try Steve Strange at Douglas Valley Breakers. Or buy an overhaul kit from Steve at SJ Sportscars
Postby Fredjohn » Fri 11.01.2019, 17:25
Usually it is the 3 plastic tabs (or the plastic gear) that break, not the motor itself.
If you operate it by hand (turning the knob on top), and nothing happens, then the tabs (or gear) are shredded. If the pod does come up, then yes it may be that the motor has gone. When you open it up, the gearbox case will be full of small plastic bits like semolina: that's the remains of the 3 tabs!!
If so, it's an easy fix and as Rambo says kits are available from SJS. They are also available from LEC member wayne on his shop website
By the way there is also another LEC member on the IOW: daveiow
Good luck with the repair.
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Return to Elan Parts - Wanted
