Windscreen Wiper Blades
Postby TD2 » Fri 29.03.2019, 16:00
Looking to replace my windscreen wiperblades, whole blades needed, and wondered what is a good option bearing in mind the screen curvature.
As you might expect the M100 is not generally to be found in catalogues!
TD2
Re: Windscreen Wiper Blades
Postby John_W » Fri 29.03.2019, 16:13
Have a look at these two threads:
viewtopic.php?f=32&t=25677&p=325070
viewtopic.php?f=32&t=14157&p=189177
or do a search on “wiper”.
Or have a look in the Wiki http://wikilec.com/view/Wiper_Blades
Postby par » Fri 29.03.2019, 18:07
Or as you are on the frugal side of the border fit a Jamie N single wiper conversion and half the cost of your wiper blades :D
par
Postby lotusflasherman » Sat 30.03.2019, 17:23
par wrote:Or as you are on the frugal side of the border fit a Jamie N single wiper conversion and half the cost of your wiper blades :D
:lol: .. but then make sure you never drive in heavy rain ... my Eclat has a single wiper and it spends far too long sweeping across the bit I do NOT look through, however fast I set it. Bloody silly idea if you ask me.
My post here has details but Eurocarparts has 55% off today so a pair will cost £17.49 ...
forum.lotuselancentral.com/viewtopic.php?f=32&t=25677&p=325070#p325090
Postby Rambo » Sat 30.03.2019, 19:24
Go for it Ian. I doubt you will get cheaper for premium blades ? I've just ordered a set for myself with my race day winnings :burnout:
PS the code is sale55 :wink:
Postby John_W » Sat 30.03.2019, 19:50
I agree with Phil’s dislike of single wiper systems. My wife’s Toyota only has one and it seems over-large and has to work too hard to clear the screen (which it doesn’t do very well).
I have now modified the blade carrier and wiper arm by drilling a hole in it to take a lock-wire after the blade flogged itself to death one rainy night, flew off the arm and exited into the countryside somewhere. As she certainly couldn’t drive with no screen-cleaning or a wiper arm scraping itself over the screen, that required me to go on a rescue mission with a spare blade from my supply in the garage. And I got very wet fitting it. :evil:
Postby Rambo » Sat 30.03.2019, 20:12
I'm thinking of returning my McLaren single wiper system to the dual system, hence ordering the new blades :?
Postby TD2 » Wed 03.04.2019, 09:24
TD2 wrote:Looking to replace my windscreen wiperblades, whole blades needed, and wondered what is a good option bearing in mind the screen curvature.
Hi all many thanks for the comments. Have gone for Bosch Aerotwin Retrofit courtesy of Wiperbladesuk.
AR21U / AR22U product codes.
I see that the consensus for the single blade conversion is more style than substance.
TD2
Postby david924s » Wed 03.04.2019, 13:20
I bought Jamie's car with single wiper and it works well although it does leave the top of the screen unclear so if you are short in the body and look through the lower half of the screen you are fine or have to get used to it and live with style over function. I can manage fine by adjusting my viewpoint if it rains, car hardly goes out in the rain anyway so can get by for the few times I get caught out. Managed fine for the last 100 miles bringing it home from Scotland in heavy rain just have to learn to cope and easy enough to swop back to double system if I want to.
Does look cool though!!
david924s
