Postby markv » Thu 11.07.2019, 23:39
Sorry, we were caught up in the Gatwick closure, so stuck at Paris CDG!
Postby muley » Mon 12.08.2019, 15:41
OK. Anyone else planning to go this Wednesday 14th August?
Jim&Jen
Postby chris.t » Tue 13.08.2019, 22:54
Yes we'll be there but be warned I'm Mr Grumpy at the moment. Siatica and a tooth implant, which I fear has gone wrong have not put me in a good place. Oh and the weather is going to be crap! Oh and Boris is PM, oh and ......
Postby rjbean » Wed 14.08.2019, 10:32
Sorry, didn't realise it was the 2nd Wednesday already! Michelle and I can come tonight... hopefully we can all help to cheer you up, Chris
Postby muley » Fri 16.08.2019, 17:41
Well, the usual culprits turned up despite the lousy weather and stupid roadworks near Farnham.
We discussed the SS&S and have decided to have it on Saturday 31st August.
We will have BBQs at Bolderwood in the New Forest, starting at 11 ish or whenever.
Hoping for good weather...
Postby muley » Thu 29.08.2019, 14:54
muley wrote:Well, the usual culprits turned up despite the lousy weather and stupid roadworks near Farnham.
As of Thursday, weather forecast for Saturday is OK-ish. Chance of showers in the afternoon?
I'll send PM reminders to the usual suspects.
Postby chris.t » Mon 09.09.2019, 14:47
As mentioned at the SSS we're giving this months meet a rest. See you all in October :)
C&D
Postby muley » Sat 05.10.2019, 22:13
OK. Anyone up for a meet on Wed 9th October?
Chris will be drinking non-alcoholic drinks ..
Postby chris.t » Mon 07.10.2019, 23:21
I'll be there, not having any alcohol put me hospital, tell you about on Wednesday.
Postby texas2201 » Tue 08.10.2019, 04:57
I might be able to make it..... :-) put new coil packs in and now it won't start...
Postby texas2201 » Tue 08.10.2019, 11:57
Sorted....took it all apart...checked and cleaned everything.....sprayed all electrical connections with contact spray.....all good will do a test drive and see if it had cured the misfire. So see you tomorrow
Postby texas2201 » Tue 08.10.2019, 16:55
texas2201 wrote:Sorted....took it all apart...checked and cleaned everything.....sprayed all electrical connections with contact spray.....all good will do a test drive and see if it had cured the misfire. So see you tomorrow
runs better but misfire is worse when hot - now I have backfires and multi misfires under load - I am suspecting it is the leads but they were brand new four years ago?????
Postby RonR » Tue 08.10.2019, 19:18
Texas, have you replaced your spark plugs recently?
I had a similar misfire under load last year on new plugs. Put the old ones back in and hey presto - no misfire!
Postby texas2201 » Wed 09.10.2019, 07:46
RonR wrote:Texas, have you replaced your spark plugs recently?
Yes last year.. had a look at them and all look ok.... Going to check the injector connections
Postby Nickydee » Wed 09.10.2019, 10:42
Hi All
Unfortunately cant make it tonight. Was planning to come along but need to meet up with a friend who is having a rough time at the mo and needs some support. Be good to catch up in November.
Postby daveiow » Wed 09.10.2019, 14:05
Hello all
Another ex-Elanner who can’t get there tonight but will almost certainly be along in November :D
"live long and prosper"
Evora n/a
Alfa Sud 1.5ti long gone!
daveiow
Postby rjbean » Wed 09.10.2019, 17:51
Sorry for late reply, i'm coming but won't be carverying and I'll be on my own as Michelle is at college
Postby texas2201 » Wed 09.10.2019, 18:59
Sorry just got home and the weather is appalling.....not cured the misfire and now the engine light is on... I'll pass tonight and see you in Nov
Postby markv » Wed 09.10.2019, 20:21
Apologies, just home from work. We have put the November meeting on the calendar and hope to catch up with you all then (and hear all about Chris's adventures!)
Postby chris.t » Wed 09.10.2019, 21:14
