Jacking point
Jacking point
Postby M100TURBOFR » Fri 02.08.2019, 15:36
Hi
Where can I pick up the jacking point large diameter washer incorporating the hexagonal bolt. Any likely sources?
Thanks.
M100Turbofr
M100TURBOFR
Re: Jacking point
Postby John_W » Fri 02.08.2019, 17:21
David,
The bolts in my jacking points are not hex-head but are Allen bolts with a slightly tapered round head. I found that I could re-use them but if they had needed replaced I would have used a cap-headed Allen bolt which would provide sufficient location for the scissor-jack.
The large washer on mine was rusted beyond redemption, so I replaced it with a large square zinc-plated washer about 1/10” thick and 1.5” to 2” square that I had in the garage. (I think it came from B&Q!) It takes the jacking load fine.
Re: Jacking point
Postby wayne » Fri 02.08.2019, 17:44
Looking on DeRoure, they seem to be obsolete. Deroure
If you need a rusty one that will need sand blasting and cad plating / painting I can send you one for the postage costs from Bahrain to France. Looks like surface rust and not too deep.
but as John said, it's an Allen head and not a hex head.
http://www.elanm100.com
wayne
Re: Jacking point
Postby John_W » Fri 02.08.2019, 18:38
Interesting...
There’s no tie-down loop on any of my jacking points, and there’s no evidence of them ever having been there.
Re: Jacking point
Postby wayne » Fri 02.08.2019, 18:59
John_W wrote:Interesting...
Maybe it was a ROW / US car thing? Both my car and the donor car have them. the DeRoure link also shows them fitted Itm 12.
wayne
Re: Jacking point
Postby M100TURBOFR » Fri 02.08.2019, 19:15
Silly me, too quick in sending - of course it's an Allen bolt (slightly rounded). Yes something zinc-plated (and strong) might do the trick.
Wayne - that's a strange contraption!! Thanks for your offer but I think I'll try and fix it otherwise.
I'll continue looking.
M100TURBOFR
Re: Jacking point
Postby GeoffSmith » Fri 02.08.2019, 19:56
Or maybe it was a dealer thing…
012 4 A100A0732F Description: Tie Down Eye Notes: Fit to jacking points, for transit only.
USB ElanScan interfaces - £60 incl. P&P.
Re: Jacking point
Postby John_W » Fri 02.08.2019, 20:15
Mine came originally from Frosts of Chichester (via Bell & Colvil). Maybe they read the memo!
Re: Jacking point
Postby Giniw » Fri 02.08.2019, 21:53
GeoffSmith wrote:012 4 A100A0732F Description: Tie Down Eye Notes: Fit to jacking points, for transit only.
Interesting, I wasn't aware of this accessory.
That makes sense it's for transit only since the jack cannot seat properly on the washer with it still installed!
Giniw
Re: Jacking point
Postby Simon_P » Sat 03.08.2019, 00:13
Giniw wrote::-D
The Dealer Pre Delivery Inspection gives instruction to remove them - I think its written in the Workshop Manual.
That could be the only one in existence Wayne.
Re: Jacking point
Postby wayne » Sat 03.08.2019, 07:38
Simon_P wrote:
Giniw wrote::-D
That explains a lot Simon. Thanks.
Typical of the dealer here not to RTFM. That said, it was the Ferrari dealer that imported the cars :lol:
It does make jacking interesting. Will probably remove them from my car.
wayne
Re: Jacking point
Postby Rambo » Sat 03.08.2019, 08:57
Giniw wrote::-D
No' I can't see how you could safely use the OEM scissor jack with that in place :shock:
I'd get them removed as quickly as possible Wayne
Re: Jacking point
Postby chrisP » Mon 05.08.2019, 13:32
You could have custom Stainless steel ones made by these people: https://www.lasermaster.co.uk/easy-order - I wish I had known about them before I handmade titanium ones.
chrisP
Re: Jacking point
Postby M100TURBOFR » Mon 05.08.2019, 14:33
Hi
Noted thanks. A possibility to bear in mind.
M100TURBOFR
Users browsing this forum: griff200pdx and 0 guests
