Fitting a Sat Nav
Fitting a Sat Nav
Postby KenS » Mon 12.08.2019, 21:07
A few pictures showing the fit of a Sat Nav in the Ash tray slot. Constructed from a B & Q (flat pack cantilever type) hinge with its overcenter spring removed, mounted with 1mm fibreglass plates which attach to the ashtray cavity and back of the sat nav with Velcro. A 3D printed support for a magnet firmly holds the assembly shut in place of the original hinge spring which was a bit too strong. The only permanent mod to the ashtray cavity is a drilled hole to pass the usb cable through. Keeps the sat nav as close to the dash as possible, just out of the way of gear changes. The hinge action allows the power button on the top edge to be accessed. Can easily be removed via the velcro and the ashtray refitted whenever necessary. Done a fair few miles now - Castle Combe and Spain, with nothing causing it to fall open, the hinge holds itself back when vertical, bolstered by the magnets.
S2 NMY #285
KenS
Re: Fitting a Sat Nav
Postby petezipp » Mon 12.08.2019, 21:49
Nice job my man
Ive got a flip up but cant get new maps so not ideal.
That looks a very neat option.
See that in the sky is it a Tesla No it's a Mitsubishi MU-2 in Lotus ,Black & Gold
petezipp
Postby John_W » Mon 12.08.2019, 22:13
Nice lateral thinking and use of the cabinet hinge. Looks like you’ve got a similar Garmin to mine, but I just used the standard mount which works well as shown here.
Something I found worthwhile was getting a non-reflective film for the screen - helps immensely on sunny days
I need to get round to drilling a hole for the power cable!
Postby Rambo » Mon 12.08.2019, 22:21
My sat nav (Garmin like yours) just jams in the fag place. Only falls out when I go over potholes :D
Postby dapinky » Tue 13.08.2019, 11:42
Mine is in the same location, but being a smaller Garmin unit, fits totally inside the ashtray hole (I used the plastic 'bubble' thing that it arrived in as a base for a fibreglass mold to hold it securely).....
..... unfortunately it is now so old that it is starting to play up a bit, and it isn't easy to find a new one small enough to fit the same hole, so it doesn't get used.
Postby Rambo » Tue 13.08.2019, 14:51
My Garmin is 14 x 8.5 cm and with the attachment (less the gimble thing that sticks on the screen) it just jams/wedges in the ashtray hole. I let the lead dangle and just use the fag lighter fir power.
Nothing sophisticated but it means I can simply move my satnav from M100 to van to M100 very easily. I must admit though that Ken's idea is much smarter and a touch more sophisticated
Postby Fredjohn » Tue 13.08.2019, 17:22
I fitted a single DIN stereo with sat nav included and it has a 7" screen which flips out and up at the press of a button. OK so it partially blocks the air vents when up, but at least I have a big screen I can read!
And I have the benefit of Bluetooth and flash drive music too. :D :D
Elan S4 DHC 1969
Evora 2010
MB CLK 320CDi 2007
Swift Sundance Lifestyle 500
Postby dapinky » Tue 13.08.2019, 18:08
Rambo wrote:..... I let the lead dangle and just use the fag lighter fir power.....
Unfortunately, the fag lighter (by definition) is needed in my car for.... the fag lighter :oops:
Postby GeoffSmith » Tue 13.08.2019, 19:30
My TomTom is too old to take the new maps - bastards! So I use a phone with wego.here.com, stuck on a magnetic butt-plug rammed into the air vent.
USB ElanScan interfaces - £60 incl. P&P.
Postby clemo » Wed 14.08.2019, 19:29
GeoffSmith wrote:My TomTom is too old to take the new maps - bastards! So I use a phone with wego.here.com, stuck on a magnetic butt-plug rammed into the air vent.
And how well that has worked out for us in the past.
clemo
