by roy666 » Thu 29.08.2019, 16:11
Hi Guys - just discovered that there are no washers on any of my driver' seat bolts; these are the ones that fit into the hole on the seat runner for the bolt to sit centrally in..."shouldered washer"..is that the correct name? I've looked in the parts list but can't seem to find them.... Anyone know a part num?..cheers Mike
roy666
by Rambo » Thu 29.08.2019, 16:27
- Don't push me
by John_W » Thu 29.08.2019, 16:54
There is a shouldered washer-type thing which fits in the hole in the seat runner to centralise the head of the seat bolt and ensure that it does not foul the moving bit of the runner in its furthest forward position.
As far as I can see, so long as you're not a short-arse, the seat should be OK without the "washers". Best check that the rear bolts don't foul the runners either.
- Heid-bummer
by Brit-Car-Nut » Thu 29.08.2019, 21:31
He means the shouldered washer that fills the larger hole in the seat rails and keels them centered on the bolts.
Part # B100B0076F £3.67 each from a Lotus Dealer or the same price from SJs.
by roy666 » Tue 03.09.2019, 08:11
Thanks Chap..and BCN (got the part num).. it is the shouldered washers. I'll source ..cheers mike.
roy666
Return to Interior
