by GeoffSmith » Tue 03.09.2019, 20:51
TOSSPOT!Rambo wrote:GeoffSmith wrote:An eclectic mix of lesser spotted LECers.
No Dico though
No group buy.
- Kitty Fiddler
by sideways » Wed 04.09.2019, 01:19
lotos wrote:I haven't given all of this much thought...
Aye.
sideways at speed
Delta BC Canada
sideways
by Graaf » Wed 04.09.2019, 13:00
Does anyone have any experience of up to date-ish costs for resprays same colour and different colour?
Graaf
by Brit-Car-Nut » Wed 04.09.2019, 13:45
I can't help with UK costs, but I can say that it is extremely expensive to have a "professional, recommended " shop screw up a full, same color repaint and have to take it to another and have the mess removed and then repaint the car. There are few legal ways available to force the first shop to refund their fees and it would have cost as much to take it to a judge, so I just saved up my pennies, let the paint cure for a few years and had a better shop do it right.
I have over $10k worth of paint, materials and labor tied up in my project.
Be very careful when choosing a shop to paint an M100. The process is not normal and even using the correct primer (color as well as composition) is critical to a decent job.
NMY requires a WHITE base / primer coat to make it look right so you actually end up paying for 2 paint jobs since the prep labor is done twice as is the actual painting of each color.
The Lotus repair manual clearly states the sequence needed to paint the car, but I didn't think I needed to teach the first painters as they were highly recommended and arrogantly assured me they had painted many Lotus in their past lives.
by wayne » Wed 04.09.2019, 20:25
Would have thought that changing the colour would de-value the car? For me, I would not buy one that had had a colour change.
Just a thought, you could have it wrapped for a lot less money and then just remove it when you sell it?
http://www.elanm100.com
wayne
by muley » Wed 04.09.2019, 22:01
wayne wrote:Would have thought that changing the colour would de-value the car? For me, I would not buy one that had had a colour change.
Not a bad idea. Mark and I see a wrapped M100 at Silverstone every year and it looks quite good even up close. With this option you can let your imagination run riot. WW1 dazzle camouflage anyone?
by Rambo » Thu 05.09.2019, 09:12
Yes, and the car to which Jim refers to in a sort of burnt collapso red, has been wrapped for about 4 or 5 years ago now and still looks good.
I saw a lovely wrapped example on a modern saloon at Boness hill climb last Sunday. It was in bright metallic green. I quite fancy doing an M100 in Lambo. orange aka Stevo
- Don't push me
by theelanman » Mon 09.09.2019, 07:40
not wishing to sound like a stick in the mud.....but.......I've heard several horror stories about wrapping too........
not so much the finish....but about the removal of stuff that's been on a long time...(4~5 years)
I suppose its like anything else.....if you get a good quality product it comes off easily......if its just cheap sticky back plastic then who knows what'll happen when you try to take it off......
just a thought.........if it was me Id probably go with the genuine 3M stuff.........
by simonbuk » Mon 09.09.2019, 09:59
Asked a friend of the family who has his own body/paint shop about the cost of a respray when I had Kermit.
Sent him some photos and he said anything between 2 and 4K depending upon the condition.
It's an expensive thing to do !!
Black S2 No.357
Aqua Blue S2 No.385
simonbuk
by theelanman » Mon 09.09.2019, 11:12
I looked at wrapping the Elite.......the cost for wrap was only about 15% cheaper than paint....so I went with paint......
on the basis that you will without doubt need to change the wrap in 3 to 5 years.........based on the fact that thats the life expectancy most suppliers seem to work on......
by Graaf » Sun 10.11.2019, 21:05
Just as a matter of interest, i've just had a quote from a local spray shop - does local Lotus dealer stuff.
If I strip the car down: lights, mirrors, bumpers, locks etc, £5.5 - 8.5K. Same colour, including door reveals but excluding engine bay, underside of bonnet and boot.
Won't be having it done there.
Graaf
