lotusrepair wrote:I was hoping that removal of the pad would give me better access to the area behind it. Looks like that is not the case. I gather that since this was not offered on the cars not in the USA that the area behind it is solid.
I believe the vac tank is up under there somewhere. I need to get to the vac lines.
It isn't "solid" behind the knee bolster, but there isn't much room to do anything. I replaced my steering column with a UK / adjustable one and used a European lower dash cover instead of the block of vinyl.
The vacuum pod is behind the LH wheel arch liner, so you need to remove it to service the hoses and possibly the tank/pod itself. It is a GM part, so not uncommon.
While you are in there, you might want to consider replacing the fresh air intake connector that if it is original to the car is probably a mess.
If you need any pictures, I can take some since I have a couple of cars partially disassembled.
I looked for the pictures of the bolster removal, but I guess I trashed them and got too busy to take new ones.
I have a few of the clips if you broke any.
You might want to look at this post I made a while back:
viewtopic.php?f=30&t=27506&p=353761#p353673It shows the bolster out and the new part that is replacing it.
