B100B0536F replacement
Postby muley » Thu 26.09.2019, 19:32
OK. This part (Slider mounting boss, front upper) failed on the Palacio Elan. This is the third Elan I've had where this happened.
Not sure who engineered it, I've always been baffled how 5 turns of an M4 screw into nylon was ever going to stand the window being forced against the A post seal.
Anyway, they ARE available - I've bought them in the past.
This time, I baulked against the £4.95 P&P
So, I bought a 30mm long CSK head M4 and a low profile M4 locking nut from accu.co.uk
Then I screwed the boss to the glass and trial fitted the slider block. Had to trim 5mm off the set screw. Tightened the locking nut with some angled pliers.
Re-installed window and all good.
Note : could have used 25mm set screw.
P.s. I had superb service from accu ~ really quick delivery by courier.. ..big product range.
1995 Palacio S2 no 507
Re: B100B0535F replacement
Postby John_W » Thu 26.09.2019, 23:01
DeRoure lists it as B100B0536F.
Postby muley » Fri 27.09.2019, 06:44
John_W wrote:DeRoure lists it as B100B0536F.
Apologies Fixed
Return to Doors and Windows
