Elanscan frustration!
Moderators: theelanman, dapinky, GeoffSmith, Dave Eds, DaveT, Elanlover, muley, Nige, Enright, nitroman, algirdas, Sy V, Specky, clemo
Postby Steve A » Mon 06.05.2019, 17:40
:banghead: As some of you will know at Hethel last year I had a problem with my ECU.
At the time we couldn't get ElanScan to work, I thought it was all down to the ECU.
However now I have a different ECU but still no ElanScan ?
I have tried my lead on other cars and it's fine, but have also tried different leads laptops on mine.
I have also carried out a continuity check of all the wires going to the Al dl plug.
12V across pins F and A, checked pins G (orange and yellow) and pin B (white and black) which go to the ECU A8 & A9 which was good.
Any suggestions would be appreciated :bonk:
Re: Elanscan frustration!
Postby GeoffSmith » Mon 06.05.2019, 18:17
Does it go into service mode when you short out pins A & B?
Is there ~5V on pin G wrt pin A when you turn the ignition on?
Is there ~5V on pin B wrt pin A when you turn the ignition on?
Postby Steve A » Mon 06.05.2019, 19:33
GeoffSmith wrote:Does it go into service mode when you short out pins A & B?
I'll have a look tomorrow, thanks Geoff :smt023
Postby Steve A » Tue 07.05.2019, 15:53
It’s yes to all three Geoff :?
Postby Steve A » Wed 08.05.2019, 15:44
Any thing else I can try ? :poke:
Postby Giniw » Thu 09.05.2019, 13:55
Can your lead+computer log another car without any problem?
(it's a bit unclear for me if you just tried your lead on another car, but with another computer)
Maybe you could try to send a few commands manually with a serial terminal to check if the ECU answers anything ...?
Giniw
Postby dapinky » Thu 09.05.2019, 14:30
Steve,
As you noticed at Hethel, I have 'all the gear, no idea' when it comes to elanscan - it works for me, so I don't need to understand the reasons why, so can't help.....
.....except.....
.... I am happy to post either my elanscan cable or the bluetooth adapter to you prior to CC to see if you can get any of them to work with your computer/android phone.
Failing that, I will take them with me to CC, along with my laptop - but it would need someone (Geoff/Ripo :poke: ) who understands the 'workings' to see if they can get your car to talk to anything.
Postby Steve A » Thu 09.05.2019, 15:33
:D CC is probably the best bet, with such a big concentration of experts in one place :smt023
Postby Steve A » Wed 02.10.2019, 17:10
:D Just an update,
Tried Geoff's son's gizmo at CC and it didn't work on my car but did on others.
Just changed my ECU and it is now working :bananasex:
I just need to learn how to use and understand it, but then I've only had my car 12 years :lol:
Postby Rambo » Wed 02.10.2019, 19:07
And you're still buggering about with those black rubber things :poke:
Postby Steve A » Wed 02.10.2019, 19:56
Rambo wrote:And you're still buggering about with those black rubber things :poke:
:lol: actually makes a change that I'm not :bonk:
Postby Steve A » Thu 03.10.2019, 22:39
I'm getting used to using the Elan scan (although very green).
I noticed that my boost was a bit low (not going past .5 on the gauge ) and the Elan scan confirmed it.
Used the Wiki and found help with "boost leak" and I tried the bike tube trick, I then found a leak
under the throttle body, there is a "L" shaped pipe on it's own with no hose available that possibly would have come off.
Maybe it was capped and that came off ?
When doing the bike tube trick, would you expect the system to hold pressure ?
I also changed the hose to the boost gauge transducer as this looked like it was well over due.
I then went for another drive and the boost went up to .8 with 60 percent throttle (this is with a 1499 mountain chip). :burnout:
Postby Giniw » Thu 03.10.2019, 23:21
If I were you I would disconnect the battery so the ECU will not use an outdated correction term it made when it leaked (otherwise it might have a tendency to overboost temporarily?)
Anyway, I suspect you will be very happy with the extra power, and the turbo will not turn too fast any more, which is very nice!
Giniw
Postby Steve A » Fri 04.10.2019, 08:43
It's strange how I had this L shaped tube tucked away that was uncovered ?
Maybe it was capped and it just fell apart with age ?
I forgot to mention that when I started it, it used to over rev which also pointed me towards the leak.
Once again the LEC forum comes up trumps :cheers:
Postby rip » Fri 04.10.2019, 08:52
Steve A wrote:Just changed my ECU and it is now working :bananasex:
That would be my old spare which was faulty then? I feel bad for that. Maybe we can arrange some sort of apology settlement?
Postby Steve A » Fri 04.10.2019, 12:14
Hi Ian, as far I'm concerned your ECU works perfectly fine, Elan scan did work on my original and then it didn't, I don't think it would be fair to say it's conclusively linked to the ECU,it could just be the plug.
I didn't buy the new ECU because I though there was a problem with yours, it was a group buy that was well worth doing at the time. :smt023
Postby Steve A » Sat 05.10.2019, 08:10
Giniw wrote:If I were you I would disconnect the battery so the ECU will not use an outdated correction term it made when it leaked (otherwise it might have a tendency to overboost temporarily?)
Good advice taken :smt023
Return to ElanScan
