by dapinky » Sun 05.01.2020, 20:40
Steve,
The simple answer is "No".......
.... but only in so much as it wasn't standard from the factory, (or even a published option) - but they did fit the system to a few cars as a 'special order' or a dealer option, but I've only seen it on 1 UK SE, and a few ROW cars.
When the S2 was produced, it was a 'standard' fitment - but you could opt to have it deleted (but I don't know of any UK cars where they deleted it).
Should you really, really want to - then the parts are still available from Lotus to do a 'proper' fitment.
Alternatively, I have added HT cables from the battery through to the boot (via a dis-car-nect switch) to allow easy access for jump leads and/or battery conditioner connection.
I have also added an extra cigarette lighter type 12V socket wired directly to the battery (via a 5A fuse) and fitted it in the bulkhead behind the drivers seat. This means I can either charge a phone or connect a solar panel/battery conditioner without having to have the ignition on.
