dapinky wrote:I have always done '3-second gearchanges' unless in an absolute hurry, so it has always been a precise process......
dapinky wrote:As far as the sill plates go, they are a 2-piece fitting....... the lower plate is attached to the sill with a number of fir-tree fasteners, and then the top (shaped/molded) piece is attached tot he lower plate with double-sided tape.
I have managed to remove them previously by carefully levering them up and out of the holes using a plastic pry bar, and then seperate the parts when it's on the bench.
dapinky wrote:Whilst I remember it taking a bit of time to get used to the short shift in my car, it wasn't too bad at all (but i actually prefer the length of 'shift' without the short-shift!).... that said, I have always done '3-second gearchanges' unless in an absolute hurry, so it has always been a precise process......
Saltire wrote:You’ve been reading “Roadcraft” again![]()
dapinky wrote:Saltire wrote:You’ve been reading “Roadcraft” again![]()
I gave my last copy of the book away over 20 years ago...... didn't need it anymore, as I still have it memorised
Saltire wrote:dapinky wrote:Saltire wrote:You’ve been reading “Roadcraft” again![]()
Was that the last of the “mirror signal manoeuvre” editions, before they came up with all the new-fangled stuff?
. Completely. When I was advanced civilian instructing, 7-step Roadcrsft was the Bible, and then they tried to mess it up with lots of new-fangled additions and complications. At which point I’m afraid I said “Thanks, but I’ll pass”.
Rambo wrote:A good write up/photos etc... And even Il Pinkster gets a mention
